Figure out FPM
Larry in NW Ohio
How does a person figure out FPM of a bandsaw. I`ll have a 1725 rpm motor with a 1 1/2" pulley and a 6" pulley on the bandsaw with a 12" wheel. Thank You Larry
Figure out FPM
Larry in NW Ohio
Re: Figure out FPM
Hal
The shaft on your bandsaw will turn at 431.25rpm ( 1725 x 1.5/6). The diameter of your 12" pulley wheel is 12xpi(3.14 for practical purposes) or 37.68" so the peripheral speed is 431.25 x 37.68/12 = 1354(approx.)fpm which is also the speed of your blade. No doubt someone else will check me and correct if I've goofed. Hal
Here you go *LINK*
Dale Lenz
See link
Band saw blade speed
Hal: You got it,
Re: Figure out FPM
The diameter of the 12" bandsaw wheel is 12". The circumference of the 12" bandsaw wheel is 12 x pi.
