Fuller countersink bits?
Charles Jackson III
I am looking at getting a set of fuller countersink bits I am wondering wish set to choice? http://www.toolsforworkingwood.com/store/dept/TD/item/MS-CS.XX/Tapered_Drill_and_Countersink_Sets_-_Made_in_USA
Re: Fuller countersink bits?
Robin Corell in Atascadero,CA
I have the #6 set and rarely use it. they are well made and cut just fine. My one complaint is that the drill bits are a bit on the long side and because of the taper you can not adjust the depth down for shorter screws. i'm not overly fond of this style of countersink and generally prefer a single flute design for their cleaner cut.
Robin
Jesper, Denmark
Re: Contrary opinion......
Jesper, Denmark
I just love the tapered Fuller bits with their countersink collars. They do last forever and you can adjust the collar down on the lower tapered part with the two setscrews on the collar.
del schisler
you can buy then singley and not buy the kit with all the size's, i have use the fuller for yrs and it is the only one that is any good, get their plug cutter also and it will work very well, it is tappered 5 degrees for a tight fit, not their is another company that is sell a tappered set and plug cutter, i tried it and it was the worst buy i have made , stay away from that . i wont post the name but FULLER is the best, their are lot's of wood suppler's that supply those in singles i use #5 countersink with 3/8" tappered drill bit and the 3/8" plug cutter the best
I like them too...
John in NM
I'm not sure I prefer them over the cheap stepped countersink bit that I haven't seen for sale in ages :D but I find nothing wrong with them in use.
I've never tried their quick change set up, I just buy #6 and #8 with spare drill bits, and that covers the majority of my needs. I do usually grind flats part way up the shank of the #8 bit so the set screws will actually work for longer screws. Most of the time the set screws are keyed into the tops of the bit flutes - bad form I'm sure, but hey, it works :D
Time tested
Fullers haven't changed in decades and they still do a fine job. Tapered bits don't make much sense to me anymore, though, because all the screws I use these days have straight shanks. So, I just substitute regular twist bits for the tapered bits.
Re: Time tested
Charles Jackson III
What set do you remend Ellis?
del schisler
i am not ellis but here is what i use the # 5 is for a dry wall screw up to i belive 1 1/2" and than a number 6 drill for the bigger screw's, and if a number 7 drill for 3" would work , but i get around using a number 6 for 3" dry wall screw's, now if you are using other screw's you may have to change or match drill to screw size?? this work's for me , the reason i don't buy the kit is some would never be used just like router bit kit's, buy what you use and don't let the other's just collect dust and cost money that you can't use ? good luck
A little perspective
Hi Charles,
I don't have sets of anything. Over the years, sets get scattered or lost, parts and pieces, stop collars, bits, set screws tend to get heaved into a couple cans on the backbench, and I piece together whatever I need for a job. There are assorted other countersinks and countersinking and counterboring bits, too, not just a tidy set of Fullers. I also have some carbide-tipped countersinking bits in a few sizes as well as some one-and two-wing cutters.
Like most things in the shop, there are combinations of tools and techniques that make the most sense for a particular job. I don't know what tasks you imagine you will be using countersinking bits for, but in my experience, as I mentioned before, I don't use the tapered bits except in the rare instances where I am actually using old fashioned wood screws. So, I tend to pick a c'sink bit that has the drill diameter that is the same root diameter as the screws I'm using. This will produce only a pilot hole, no clearance hole through the piece you're attaching to some other piece. This isn't a serious issue if you've got the pieces clamped together, but if you want to use the screw to pull the joint together, you've got to take the separate step of drilling a clearance hole for the main shank diameter of the screw.
Often, say if I'm assembling plywood cabinets, where I'm screwing into the edge of veneer-core plywood, I don't bother with a pilot hole at all, and I select a c'sink bit with a larger drill bit to just drill the countersink and clearance hole through the top piece. Zipper screws (or drywall screws, which I don't use) will easily grub into edge-grain plywood without pre-drilling. Same goes for softwood assembly. In fact, I'f I'm just whacking together 2x4s or something like that, I often drill no holes at all. (Blasphemy, but true.)
Where accurate drilling becomes more of an important issue is when you're assembling parts that are of solid hardwood, especially if they're dense tropical woods that split if you look at them sideways. In those cases you need properly sized clearance and pilot holes to avoid splitting the wood. And, a proper pilot hole diameter varies with the delicacy and hardness of the wood you're screwing into. A very dense wood like ipe or ebony or rosewood will develop more than enough screw holding strength with a pilot hole that is only a 32nd or so smaller than the outer shank diameter of the screw; any tighter than that and you're inviting splitting. Softer woods like walnut or poplar are more forgiving, and you can generally use a drill bit closer to the root diameter of the screw.
So, as usual, there's no pat answer to your question. Hopefully these guidelines will help you decide how to equip yourself for the work you anticipate doing.
If I were limited to those two options...
John in NM
I would go with the first set. Using a cordless drill mostly, I have little use for a quick change set up, and I can't really see the need for tapered drills below a #6 or above a #8, so the cheaper set would fit my most used range.
I often use the tapered drill in cases where I could use a straight one, because in casual use I find it easier to wear out and replace that expensive bit than to have to keep track of another set up. If I were doing production work with them, that equation would change quickly :D
I used to buy individual bits and countersinks from McFeely's, when I used them more often. As I recall, they had countersinks sized for straight bits as well as tapered bits.
Rick L
Re: Type J are better than Type E
Rick L
Less drill breakage with Type J countersinks than Type E as you are gripping the countersink itself and not the drill shank. Started out using the type E 40 years and once I saw the Type J I never went back and so did the customers we sold the Type J counterinks to. Funny, the better product often gets ignored in favor of the better marketed one. Just buy them direct from Fuller. I see no need to use the tapered drill bits unless you are using the old tapered woodwcrews. Modern woodwcrews are straight shanked. Not need to spend the extra money.
http://wlfuller.com/html/countersinks.html
Re: A little trick I use on
Larry in NW Ohio
wood that is dense, or some of the particle boards that have a tendency to split putting a screw in the edge, even if I drill a hole, is to take a vise grip C-clamp with the swivel pads and clamp it where the screw is going into. This has always taken care of splitting for me. Larry
Charles Jackson III
Thanks guys for the advise.
Along with the countersinks, I hope you get plug
Keith Newton
If you are countersinking, you also need the plug cutters to match. The little Fuller ones are nice, in that they put a little chamfer on the insertion end, which makes it a lot easier to use than a square end.
A little tip, for when you have a lot of them to plug, drill lots of plugs on the drill press. Clean the top, tape over it with 2" masking tape, then saw 1/4" from that edge on the bandsaw. Next, mark a dark pen or pencil line down the row of plugs indicating the grain direction, then peel away the skeleton board.
I then tear off a short manageable length about 4" long, which I capture on top of a little pallet scrap about 3" x 8", beside a thick spread of glue, which I roll them on, and use to pick up a little on the end of a small dowel for priming the hole. I usually prime about 6 ~ 10 holes, then roll the plugs, and tap them in with a little 12 oz hammer. If you forget the pencil line step, it is easy to confuse the saw scratch with the grain direction.
For trimming a lot, I like to use a dovetail bit in a trimmer, with a C shape sub-base carpet taped to the router base. The C allows me to approach from the side when there are pairs close together.
And for those times like re-fastening a wooden boat, I use a router bit in a trim router with a thin piece of plastic taped to the base. Without tightening the depth knob, I can place the slightly larger hole in the plastic over the old bung, then drill right down to the old bronze screw perfectly every time.
