picture of new work
Robin Corell in Atascadero CA
Here is a picture of a bar stool I just finished. The base is welded steel with an acid finish and the seat is claro walnut.
Robin
picture of new work
Robin
Re: picture of new work
Nice piece. I'm a sucker for wood and metal combos. Some day off in the future I'll learn to weld....or so I keep telling myself.
As for the Claro...I hate you and everyone out there who are lucky enough to have it!! Beautiful stuff.
All that stool needs now is my *ss on it with a cold bottle of micro brew.
T.
(Message Deleted by Poster)
Re: God, how I just love steel & wood together, ..
Robin Corell in Atascadero,CA
Actually the finish I use on steel is Bircheood-Cassy's aluma black. I prefer the warmer tones it gives over their steel black products. Its designed to be diluted and used as a warm immersion application. I'm still playing around with different techniques for applying it cold and by hand. The results are not the even tones of an immersion bath but I kind of like the mottled look, it reads more as non painted metal.
Robin
Tubular
Shall we assume those legs are tubular stock? If so, how did you get the flare? If not, how much does this lovely thing weigh?
Nice combination.
Dude!!!!
Um, like totally!
Yeah Fer Sher Fer Sher
Hey, that's a California term
Maybe I should have said bitchin'.
Dude!!!
Not a Northern California term
except among the surfers who wonder why they live up where they have to wear a wet suit to go surfing, instead of moving south where the water's warmer.
Bill, lives in a state that should have been subdivided years ago
Patience
The Big One's coming and there'll be enough subdividing for all
Ever seen the old Junkyard wars?
John in NM
First few seasons it was all Brits. There was one where one team was all Brit surfers... the sounded remarkably like California surfers with British accents
British surfers?
Don't their boards leave oil slicks?
Re: Tubular
Thanks for the kind word Ellis and yeas the legs are made from tubing. Getting the flair at the end is not that difficult and doesn’t require any special tools. The first think I do is to slit the tubing using my Bosch jig saw and clamp it into a wood caul.
These photos are of the first leg which was a proof of concept to make sure I could make the bend without kinking the front edge and so I was using a wood bending wedge on the inside of the tubing to push the tubing into the caul.
Small filler wedges are fitted into the gaps and tack welded in place. The wedge is removed and the rest of the welding is completed and the welds ground flush.
Using a wood jig for welding is not ideal but I often do it for one off items. For the second leg I made an aluminum wedge using my band saw, disc sander, spindle sander, and table saw all with the same blades or paper I use on wood. The clamping caul gets an occasional singe but I have no plans to replace it with metal tooling.
I use thing wall tubing with a wall thickness of about 1/16” and even with the 1/8” x1” strap I use to attach the seat the base weighs less than the piece of wood for the seat. It certainly weighs less than an all wood stool of the same dimensions would weigh.
Robin
Re: Tubular
Leo Cuellar
Very nice work, Robin! Metal always seems harder to clamp than wood, but at least its easier to patch if you come up short
Glad I asked
That's pretty much the way I figured you were doing this. I'm delighted you just happened to have the whole show-and-tell to illustrate it.
Very cool design. Thanks for posting your pictures.
Re: British surfers?
Jason Roehl in Lafayette, IN
Only if it contains electronics. But their wet suit does include a fog coat.
Jason
Hmmm....
John in NM
I think you've had a Brit car or two?
Closest I ever came was a 72 Saab that had a Triumph engine. It wasn't as troublesome as the later ones with Saab engines, but it still was no picnic
All the engine parts were SAE, everything else metric. At least there were no Whitworth thread stuff (that I know of!)
Actually, no
I've just had friends with British cars and motorsickles.
The Swedish car makers had an interesting relationship with the British automotive industry. For many years, until the introduction of fuel injection in the early 70s Volvos, they used the famed SU carburetors, which provided mechanics who'd always wanted to be neurosurgeons but couldn't handle the blood an outlet for their obsession with intricacy; Girling and ATE (Alfred Teves) brakes, and (my all-time favorite British automotive company name) Laycock de Normanville overdrives. They were also prone to inspiration by British engineering practices, as witnessed by their use into the early 70s of a felt washer as the rear main seal on the motor, which felt seal would start to fail the first time you fired up the motor and usually did not have to be removed when you went to replace it, because it had long since disappeared.
Since I've owned multiple Volvos directly and vicarously through my older son*, I have a kind of indirect relationship with British cars.
*The younger one's an early 50's American iron kind of guy.
Worst of both worlds....
John in NM
I owned that Saab, my parents owned two that were worse, then I went on to a 1970 Jeep (not bad actually) and a 1960 F100 - probably spent more time fixing those than driving them.
Once I got a real job, bought a Saturn for commuting, and married a girl with a Toyota pickup, I forgot all about how to trouble shoot problems
Now that cars are at the mercy of their computers and tend to do odd things on their own, I'm again looking around for an old chunk of 1970's truck that requires constant maintenance and repairs, but doesn't lock me out on its own or accelorate when I have my foot on the brake
A guy here at work had an MGB for a while... I'll have to mention Laycock de Normanville, he'll enjoy that. I can't remember now who made the fuel pump in my Saab, might have been Girling.... horrible.... (Bob will remember, his MGB had the same pump) the rest of the fuel infection worked pretty well though, all fairly low pressure and just regular fuel hose and hose clamps.
Gotch Both Beat
1965 Supersnipe Humber
Birdseye maple and pewter trim, red leather, everything you could ever want
Including a nose-to-tail Lucas electrical system that nobody on this side of the Pond would touch.
Daytime range 350 on a tank.
Nighttime range 40 miles which was how long it took for the headlights to drain the battery leaving you f.o.r.d. because the charging system didn't work.
We called it "The Humper" because a week after you got it, you knew you'd been royally screwed.
I've heard of those... *LINK*
John in NM
I seem to recall one featured in an old Dick Francis novel
My BIL sometimes emails me car ads, so I'm sure he will appreciate it when I send him this one
http://inlandempire.craigslist.org/cto/3698235838.html
That seller is suffering from over-confidence!
