home stretch for chest of drawers
Bill Tindall, E.TN.
Got the back of the piece glued up tonight. 16 mortise and tenon joints. I have gravitated to making furniture backs a frame and panel. For one it uses up lots of resawed scrapes of lumber. The frame is 1/2", the panels 3/8" and 1/4" mortises. And it provides a finished back should that ever be important in its useful life.
The secret to such a complex glue up is to first see that everything dry fits easily and practice an assembly strategy during dry assembly. . No recalcitrant joint to be hammered together. Clamps are already adjusted as needed.
I use hide glue for this application. It "greases" the M&T joints and stays fluid for a long time so that joints can be adjusted if necessary. I mark all intersections with an alignmnet line during dry assembly so I can rapidly position the pieces when the glue goes on. The glue is rapidly spread with a spatula, coating both mortise and tenon. Then its put it all together, clamp and check for square. If precise about getting the tenon ends perfect square (I use a saw sled) the assembly will self square and this one did.
Re: home stretch for chest of drawers
roger lance
Bill....I think building a back panel is a definite elevation of the cabinet makers art....I've just been using a plywood back with most things I've done as I expect these pieces will reside against a wall....but I really appreciate a back panel and I will also move to begin to include them in future work....I know yours will only add to what will be a great finished piece.
Bob Entwisle in NJ
An elegant back, Bill!
Having just moved some furniture around recently, a cursory examination of the backs leads me to think that a more robust construction of the back panel is not at all out of line. Not to mention your back panel is much nicer to look at too.
So I counted 14 M&T, which ones did I miss? (math never was my strongest subject).
Nice job, i look forward to pictures of the finished chest.
Bob in NJ
Chamfer the ends of the tenons a little
charlie belden
If you put a slight chamfer, or even just ease the edges of the ends of tenons it'll give you a little Self Aligning, especially with tight fitting M&T joints. Doesn't weaken the joint AND provides a little room for glue. Putting a little V groove in the tenon will allow for glue squeeze out and minimize pneumamtic pressure as the joint is closed.
One of the many advantages to traditional joinery is that you can dry fit before glue up and things will be self aligning and self supporting - assuming the joints aren't cut loose.
When you make the extra effort on things that in normal use won't even be seen - YOU know. And that's something that takes your work up that extra notch.
Robert Hayward
Bill, will you put a finish on this back panel ? If so, will it be as nice as the front of the chest of drawers ?
Bob
F&P back panel a good idea
David Yoho
The use of a frame and panel back for a piece of furniture like this is a good way to go for numerous reasons. There's always the possibility that the user could position it in the room where it doesn't reside against a wall.
Whether flat or raised panels are used, there should be minimal expansion of the whole panel with this process, thus reducing that concern.
Also, ever built anything wide enough that a piece of sheet stock (plywood and such) was not wide enough to do the job? The frame and panel option can fit any size back space while providing plenty of strength.
One thing I learned from a pro builder I know is you want to make M&T joints fit snug. Using liquid hide glue allows you to do this because, like Bill said, it feels like it "greases" the joint and also allows extra open time for assembly. These days I find I use liquid hide glue much more than yellow. I save the yellow for things that will live in humid or moist areas or when the joints need to have some flex.
Finally, whether or not the back will be visible, a frame and panel back says something about the overall quality to me. After all, when you spend all the time and craftsmanship on the rest of the piece, slapping a piece of plywood on the back just doesn't seem right.
For me, I find making a back panel in this manner for large case construction my go-to method now. Well worth the time it takes!
Bill Tindall, E.TN.
I spray the back with shellac. The shellac keeps the wood "bright". Otherwise poplar oxidizes to a dingy luster. Ditto for drawers.
