Have a question? Ask Woody!
Point of use hot water heater
Lynn Reedy
I am soon to purchase and install a 2.5 gallon water heater for
my kitchen sink. It will be located under the sink and operate on
110 volts, plug-in. Every heater I research, I find about 30% of
the reviews are bad. Leaks, water temperature hard to maintain etc.
Some reviews state that maintance of the heater ever 6 months are
more trouble than they are worth.
My current choice of heaters is eemax 2.5 gallon water heater.
Does any body have any experience with this brand or do you have
a brand that is better? Thanks for the help...
Re: Point of use hot water heater
Bill Turpin in WNC mountains
What is the capacity of this heater. My rough calculations for heating 55° ground water to 120° with 1500 watts is about 1.15 lbs per minute. Take a pint jar of water and spend a FULL minute pouring it out. Will you be satisfied with the small stream? PM me if you want more info or to see my calculations.
Joseph Mulherin, sr
Lynn, most of the problems that develop have to do with poor installation.
I have had a hot water dispensor for my coffee,soups, cocoa under the sink for years and have had NO problems at all.
I have to relate that i am a retired plumber/pipefitter....35yrs in Trade prioe to retirement.
If there is not any problems with the construction of the unit, then go ahead and install it properly.
Don Evans
I have experience with the 2.5 gallon water heater that Lowes sells. When my shop was built the contractor installed that unit at the sink in the shop. I though it would be ok as all I would use it for was washing hands my eye glasses.
Turns out that it isn't much good for just doing that. I also ran it hotter that suppose too trying to get more hot water just to do one hand washing and glasses.
You must understand that as soon as you turn on the hot water cold water begins to enter the tank cooling the water that you have spent money to heat.
After 6 years it began to leak at the back (even though it was installed correctly) the fittings just rusted.
I replaced it with a 6 gallon RUUD unit, one that looks just like a regular home heater except physically smaller.
I believe based on experience, this will be not only disappointing but totally useless for a KITCHEN sink.
Total waste of money. As you can only set it for 125 deg legally expect to get about a pint of water that temperature each time you try to use it.
Don
In Germany . . .
Steve Mackay
I lived over there for twelve years, off & on. Over there they are all you see. And, NO, I didn't think much of them. Yes, the temp is un-predictable. You can get hurt in the shower easily. The supply always seemed erratic. If I kept a landlord/manager out of the apartment to work on them for a whole six months I considered myself lucky. Of course over there these move with you. Just like light fixtures and kitchen cabinets. But they still get re-installed by profesionals.
Re: In Germany . . .
Larry in nw ohio
Lynn instead of a 2 1/2 gallon, why not put a real point of use water heater under the sink. I have one in our mud room sink for the use of that sink and our bedroom upstairs, and the cloths washer next to the heater, and that works very well. The only thing you need 220 volt. Larry
Chad P
I have a little 2.5 gallon tank that I hooked up in my bathroom under the vanity. I have only had it operational for about 1 year but in that time it has been very useful. The plumber that installed it hooked it up to the hot water supply side in the bathroom. For washing hands and shaving it has been ideal. Hot water when you first start up, then lukewarm water for a little while, and then hot again when the water from the tank finally gets there.
Prior to hooking it up I had to wait about 45-60 seconds before hot water would finally get to my tap. My master bath is a loooong way from my hot water heater.
Chad
Larry in nw ohio
Lynn If we know a little more of your situation, like do you have a regular water heater for the house then what Chad suggested is the best way to go, and the cheapest. But if you don`t have a regular water heater then the point of use water heater like I sugested would work better. imho. I used them both ways and it works both ways. A little 2.5 gal. heater under the cabinet will heat the water and have enough in the tank to take care of the cold water in the line from the heater. If you have any more questions just ask. Larry
Pete in Holland, MI
Lynn -
What's the reason for the POU WH ? Takes too long to get how water to your faucet?
Couple things:
1) You probably have a 3/4" main hot water line. Change that line from your WH to very close to the sink wiht either 1/2 or 3/8" pipe. Much less pipe to empty to get to the hot water.
2) Can you put a return loop back to your main WH ? Done properly, thermosyphoning will keep the water loop moving, shortening the time you will receive hot water at the source.
3) A return loop with a small pump can keep the hot water moving thru your house and creating quick hot water at your faucet.
All these, including your baby WH, will cost you more for the instant gratification of hot water at the faucet.
Pete
2-Pipe Loops
must be well insulated for their entire length or they will cost a small fortune to run.
Re: 2-Pipe Loops
Several years ago. Lowe's had a display of a small pump unit that you put under the sink. You created a cross connection to the existing cold water line. The water returned to the water heater through the cold line. You could set a temperature you wanted at the sink and the pump would cycle on and off to keep that temp at the faucet. It was about $260, I was concerned about the energy cost, the cost of the unit and installation and I wondered what happened tot eh warm water that was returning. When you turned on a cold faucet nearby but between you and the water heater, would you get a blast of warm water? I never pulled the trigger. What seemed like a better idea that a thermostat would be to add a switch to let it circulate the water only while you were using the sink. In stead of running the water down the drain, circulate it internally until you stopped using the sink.
Re: 2-Pipe Loops
Hotels use them a lot as the guests have come to expect hot showers on demand. They will then run a recirculator pump that runs when the system is "closed" meaning when no guest room is drawing hot water. The return line is separate from the cold water supply; you could not return water to the heater through the cold supply. You need a second hot water pipe (actually a 3-pipe system) to return to the heat source. The two hot pipes are/were IIRC run in tandem inside the same insulating jacket so that "waste" heat from the primary supply radiates to warm the return line thus saving on fuel to raise the holding tank temperature back to operating spec. My family had a small hotel and when we upgraded the boiler system we replumbed the hot water lines that way. Worked very well.
Re: 2-Pipe Loops
Larry in nw ohio
Barry I put in one of these pumps and for a few years It worked very well, The little bit of warm water in the cold line wasn`t a problem, it seemed to cool off pretty quick. After a few years it would get the typycal gunk in the pump and it would need to be cleaned, not much of a problem, but still not a lot of fun. I think I would rather put a small water heater under the sink, like I said in my other post I put one under my mothers sink probably 30 years ago nd only replaced it once, and it really worked great. I think another way to do it would be to put a point-of-use heater under the sink, one that had a thermostat on it and that it would work in tandem with the main heater. Because some of the POU water heaters can not be used in line with the main heater. I guess the POU heater would burn up trying to heat already heated water. Larry
Joseph Mulherin, sr
Yes, Lynn, he had a very good point on how to circulate the HW easily. What is the age of the house; how is the plumbing installed....under the floor or in the attic? Either way I would see about installing a small line and adding a circulating 1/6hp pump for this....would be more satisfatory and possibly cheaper in the long run....and a lot less leakage and fuss in repairs.
