Have a question? Ask Woody!
Dust Collector Electronics
David Frame
Hi Eveyone,
I would like to know if there is a way to connect all of my 220 volt tools into one box and have a dust collector start with the with tool I choose to have on at that time?
Re: Dust Collector Electronics
Joseph Mulherin, sr
Methinks you would be better off going to Rockler and buying their connection box to do this. I bought one to use when I use my router table and it works just fine.
Joseph Mulherin, sr
220...NOT...110 is what it is set up for.
John McGaw
I'm sure that there is a way but it isn't going to be simple. Example: you switch on your table saw which is sensed and a powered blast gate opens while the dust collector is turned on. You turn off the saw and that is sensed and the blast gate closes while the dust collector is turned off. The key problem is that there must be blast gates which open and close under some sort of control. There probably is some sort of servo-controlled blast gate but I've not seen it and I can't see any home-shop-sized DC working properly unless blast gates are used to steer the suction where it is needed.
My system uses four blast gates, each of which has a switch that controls the dust collector through a relay box. Open a gate (or gates) and the DC runs, when all the gates are closed the DC stops. Very simple and clean and easy to install. Cheap too. My unit along with the gates is made by PSI and is available from Amazon.
Stuart Hough
John, there is a system out there that starts the DC when you open the blast gate connected to a machine, though I don't remember the manufacturer.
Re: Dust Collector Electronics *LINK*
Bob Entwisle in NJ
JDS makes these blast gate controls that turn on the dc when the gate is opened.
But this requires manually opening the blast gate to turn on the DC, and then powering on the machine. It's not activated when the machine is powered up.
Bob in NJ
http://jdstools.com/jdsdust-gateautomatedblast-gatesystem.aspx
John McGaw
As I wrote, I have such a system and described it. Mine is sold by PSI through Amazon (money for WoodCentral!) although the idea is certainly not unique to them. I saw a description of a homebrew system doing the same thing many years ago. Unless one came up with servo-controlled blast gates I don't see how a home shop could do any better. Sure, I have to open a gate and turn on the machine making one extra step but that scarcely seems a major difficulty to me and it beats having one extra step of turning on the DC also.
Don Stephan
Often I need to use machines in sequence when working a stack of boards, such as the jointer to flatten one side, then the planer to make the other side parallel, then the jointer to straighten one edge, then the table saw to make the other edge parallel. I wouldn't want to repeatedly cycle on and off the dust collector during such a set of operations. I have a separate switch for the dust collector, centrally located, and don't find it cumbersome or time wasting.
Joseph Mulherin, sr
I agree with yo0u about haqving a separate switch for the operation of the DC. If you are going to be doing sequential work like you said I would just turn the DC pn and do the work as needed instread of having the DC electronically connected to each piece...waste of time and money IMHO.
Don Evans
Save yourself a lot of trouble and energy and just put a remote controlled unit on the DC. That is what I have on my cyclone and a remote controller in my smock pocket. I can turn on and off the DC from anywhere in the shop with just the click of a button.
The systems that use switches at each gate would work but you gotta run all the wiring back to a relay plus you have to maintain it over time.
The one controller mentioned for a router table will not work for this application I don't think. Big problem with it is it is limited with what amperage it will operate so be sure and consider that before purchasing. I got one of these also for my Incra router table as I didn't want to limit that units position in the shop connected to the cyclone, so I use the vacuum on it. For it I got the unit that Woodcraft sells and when got home found it requires you to plug in 2 AC cords making sure they are on different circuitw in the shop. That made it a pain due to limiting where it can be set up. But it works ok for that application. This unit is limited to 15 amps if you plug in only one of the cords, that just runs the router nothing left amperage wise for the vacuum so I was force to us both AC inputs which works ok. (they don't explain this on the outside of the box of course).
Don
Alan in Little Washington (NC)
As others have alluded, for me the issue wasn't turning on the DC, it was opening and closing blast gates. Though not hard to do, they were often located in difficult to reach places. It was a hassle, especially for a lazy guy like me, when doing the jointer-TS rip cut, doe-see-doe. I often neglected the DC totally for quick cuts or short operations. Also, leaving more than one gate open guarantees insufficient dust collection for most home systems.
My solution, which is not for everyone, and can be costly unless you are good at scrounging and DIY, was to build a fully automatic dust collection system with electro-pneumatic blast gates triggered by small current switches at individual machine wall outlets. Activation of any gate automatically (or semi-automatically via button stations) starts the DC. To avoid cycling the DC too often and burning up the motor or start capacitor, I designed the system to only start the DC- I must turn it off manually. Running the DC with all gates closed is no problem since it actually stresses the motor less than if one or more blast gates are open.
There are posts about it here and elsewhere, and a rather long video about it at this link.
First prototype:
Actual installations:
JoeW Detroit, MI
I have sort of done this at work, but it was for 480V 3-phase machines each using it's own dust collector. In our case we had to use motor starters for all of the equipment, but you could use line voltage at home, but from what I remember it would take some creative re-wiring of the switches. In your case, we could use a relay with a 240V coil rated at the horsepower of your collector. You will have to figure how to "capture" the voltage on the load side of the machine switch. This would then be used to operate the coil and closing the contacts on the relay. Your dust collector would then be powered through the relay contacts to start when the saw started. You would have to do this for each machine and the wiring would become messy in a hurry. As others have suggested, I would use a commercially available product - it would be less costly, more compact and simpler.
John McGaw
Neat! Do you have a good source for the pneumatic cylinders and associated valves? Every time I've searched for them I've been stymied by the price. I used to live in Silicon Valley and there were any number of surplus stores there where they could be had relatively cheaply but that appears to be a thing of the past and it isn't exactly convenient to travel cross-country to scrounge through the heaps in any remaining dealers (if there still are any).
Larry in nw ohio
This is the basic operation I put in. Scronged around and probably only have $200 in the whole setup. I control the DC with a home built remote. Best thing I ever did. Larry
Just to be certain that I understood
Merle
correctly, you indicated that I don't need to open the blast gate for the next machine before closing the blast gate for the current machine??? That would save me a lot of steps!
My dual acting cylinders (Bimba), 26VDC 5-2 solenoid air valves (SMC), and current sensor switches (MRC Magnetics) were purchased on Ebay. Minus the cost of the actual gates which were made from MDF, laminate, and 6" of pipe or 1/2 of a coupling, the cost of each autogate ran about $20 each. That required significant scrounging and a bit of luck.
The solenoid air valves, current sensor switches, main 30A/240V DC contactor relay coil are low voltage connected with inexpensive bell wire which made wiring easy. One hot lead (110V or 220V) at each wall outlet that serves a machine with a blast gate passes through the center of a current sensor switch toroid- there is no physical or electrical connection.
Yes, the DC can remain running- no need to worry about opening one gate before closing the the previous one. The DC motor works least with all gates closed.
I hope this answers all questions.
MRC Magnetics current sensor switch. Small orange and black wires are low voltage switch leads. Large black wire in orange Romex is "sensed" lead:
John McGaw
Guess that means I need to redirect my scrounging to eBay even though I hate that place and have been ripped off in the past. Or I could just keep doing the blast-gate-opening manually until it becomes too troublesome. Thanks for the information.
Robert Fuller
+1 on the advice given by Don Evans. Just use a remote.
You can buy a remote from Rockler or others, or build your own as I did.
I bought a remote light switch and a 4x4 junction box with cover from BORG, and a 110V relay with dual 30A contacts. I wired one side of each contact to my DC (220V) and the other side of each contact to the 220V source. The coil of the relay was wired to a plug that connected to the remote control box.
I just push the remote and it activates the relay, providing 220V to the dust collector.
Another push whenever I want to shut it off.
I do still have to manually control the blast gates, but careful placement of them on the wall makes them easy to reach.
