Ice maker Question
Ice maker Question
Ice maker Question
I have a Kenmore Refrigerator that has an Ice Maker in the freezer. The Ice maker quit working so I bought a new one. It worked for a while (less than a year) and now it seems to have slowed down or stopped. We have started buying ice to supplement it.
I thought these things ran at a consistent pace on some sort of clock mechanism. A friend tells me they are very temperature sensitive. I turned it down in the refrigerator compartment. The temp in the freezer is nineteen degrees. Any suggestions?
(My son is on a soda binge and I am not sure he is not just running over the thing.)
Re: Ice maker Question
Larry in nw ohio
Barry This may take a little looking around. First does the fridge have a filter on it. If that has never been changed, that might be doing it by not letting the water flow through it from gunk build up in the filter. One thing you might try to check out the filter. I take it that this fridge has an ice dispencer on the outside in the door. If so take a cup and put nin under the water outlet and take a watch and time how long it takes to put so much water in it. Have your watch ready and push in on the cup to get the water going into the cup and after maybe 1/2 a minute look at your watch and check the time and pull your cup out and remember how much time it took to fill the cup to where it is. Know take a black marker and make a line on the cup to where the water is. Now dump the water out and take the filter out, I hope you can take the filter out without turning the water off. Now with the filter out check to see how long it takes to fill the glass to the line and compare that with the time with the filter in. If it takes longer to fill it to the line with the filter in, you need to change the filter and that may be the problem. Good Luck. Larry
John McGaw
Most icemakers work in the same way and there are very few deviations. just minor mechanical variants. When the sensor (bail) detects a low ice level a valve opens and meters water into the mold. A thermostat detects that the filled mold has dropped to a preset temperature showing that ice has solidified. This freeze sensor triggers a short heating cycle from an electric element under the tray to loosen the ice and then the ice is mechanically forced out into the bin. I believe that the bail switch always halts the repeating cycle at a point between the detection of freezing and the beginning of the heater cycle meaning that it should always be ready to eject a set of cubes when the bin level drops. Since it is a cycle, a defect in any part of it will eventually halt everything.
In my personal experience, I've been plagued by frozen filler tubes which prevent the tray from filling but I don't know how common this particular problem is. Others report blocked water lines and filters, defective solenoid fill valves, and jammed ejection motors as frequent culprits.
Freezer not cold enough
Doug
You said " The temp in the freezer is nineteen degrees". If that's true then your ice tray temp sensor doesn't think the ice is cold enough so won't flip the tray. Your refrigerator should be set at 40 F and the freezer at ZERO or maybe 2 above Zero. Then your ice maker sensor will work better.
Re: Freezer not cold enough
Okay, I just checked again. The lower compartment is at 40 Degrees and the freezer is at 19 Degrees. The temperature control in the freezer is set to max cold in the freezer. The control in the refrigerator is set near the coldest setting.
This is not a through the door ice maker, its the older in the freezer only. The coil for this fridge is on the back. It has never been dirty. Should I move the whole thing out from the wall a little?
Wonder if this could be low refrigerant (Freon?)
Have you found a solution, John ?
Yonak
John, I also have a similar problem as yours with my GE refrig./freezer except, instead of the filler tube to the ice maker getting frozen, it's the tube to the through-the-door water. The ice maker works fine.
It goes through phases. It will provide water for a year or so, then stop providing water for a year or two. This cycle has happened three times and it's now not providing water. I feel like the supply tube may be frozen.
Were you able figure a way to thaw the water in the tube in your freezer without unplugging the refrigerator ? Lowering the temp. in the freezer doesn't seem to help, nor does replacing the filter.
John McGaw
Could be any number of things. For example, if this is a self-defrosting freezer then the defrost controller could be malfunctioning and a mass of ice might be covering the evaporator coil. Or the blower that is responsible for moving air over the evaporator could be malfunctioning. I really should have caught your mention of the freezer temperature before. 19 is way too high and I'm pretty certain that the thermostat in the icemaker wants to see the mold at least 10-15 degrees colder than that to keep the cycle going.
If you can find how to get the internal shrouds in the freezer compartment off you should be able to see both the evaporator fins and the fan and any problem with them should be pretty obvious.
Joseph Mulherin, sr
We have a side by side Fridgid-aire fridge/freezer. The freezer quit making ice. I had to replace the entire unit last year. Cost was about $82 and simple to install.
Re: Have you found a solution, John ?
John McGaw
The frozen filler line has happened to me multiple times with two different old appliances. With the later Jenn-Air, now disposed of after the compressor finally failed, the key was to disconnect the flexible rubber feed tube from the solid supply line at the back of the fridge, remove the internal section, thaw it, re-install and re-connect. With that appliance it was pretty easy due to the construction and only took ten minutes or so. If I were to happen with my new Whirlpool I don't know how I'd approach it. Maybe a heat gun (I don't have the safer hair dryer being follicularly challenged). Total meltdown should always work but that is not an attractive alternative for anyone.
John Veerkamp
as others said, 19 is way too warm for a freezer. Several good ideas on fixes. One not mentioned on the maker, if the water flow is not adequate, it won't work. I had to replace my saddle valve where the ice maker line connected to the house water supply. Those self piercing valves often get calcium blocked. I always drill a hole for the valve rather than relying on it's self pierce.
Jerry Roberts
My Kitchen Aid i m quit a few years ago. I just bought 5 ice trays and do it myself. I do remember right after we bought it a repairmen came out and said there was a recall to add a heater circuit to keep the water warm enough to reach the i m. I know im not getting water to refill it but I guess Im just too lazy to have it fixed.
