Listening to Knuckleheads, Click & Clack,
Keith Newton
On their puzzler, they were describing how to use the battery, and wire, to magnetize a screwdriver. Those knuckleheads gave a bad answer, which could be a bit hazardous. They described leaving the wire hooked up, making a electromagnetic. The problem, is a direct short across the battery terminals, will get too hot to hold in seconds, and might blow the battery up.
Back when I was a young carpenter, before all the suppliers had apex bits, and the handy little magnetizers. I would cut the handle off regular + drivers which we magnetized on my truck battery. All you have to do, is wind the wire around the shaft about 6 times, hold one end to one terminal, then drag the other across the top of the other terminal. Sparks will fly, but whatever you do, don't stop, or it will self weld and burn your hands.
I've needed to use this a few times lately when we were away from the shot, and only had new bits. My helper Ben, says he is going to buy one and tie it to me somewhere. A week or two earlier, while wearing some really old jeans with a hole in my pocket, a bit found it's way into my boot. I dint' feel it fall, and only noticed it when it made it under the ball of my foot. We had a frantic pace going, and I complained a bit before stopping. When I did stop, and pulled it out, I said, "Damn, If I'd known it was that, I'd have stopped this morning to take it out."
Ben decided that tying the magnetizer to my boot string would be perfect, since that would be close to where I keep the bits. ha
