OT-Lock Lube?
tom
The locks on my truck cap are beginning to stick. I was wondering what others have used to lube these locks?
OT-Lock Lube?
tom
Re: OT-Lock Lube?
Jason Roehl in Lafayette, IN
I'd get some solvent in there to clean them, like brake parts cleaner (it's a strong solvent, but it's very volatile, so it doesn't tend to damage other things). Then, use either silicone spray or graphite. Don't use WD40, as it will allow dirt to stick.
Jason
P.S.
I'd make sure any exposed rods and levers get cleaned and they might even take a dab of grease at any rub points.
Jason
Try Lock Ease
Lee Schierer McKean, PA
Lock Ease is a good lubricant for locks of all types. It also contains graphite so lubrication remains even when the oil dries out. Most hardware stores and big box stores carry it.
Lee
Re: OT-Lock Lube?
Jason Waters
I'd be careful with brake parts cleaner, it can take the finish off stuff around it. It's not as bad a carb cleaner, but I don't think I would start here.
I've seen painters not remove locksets, paint around them, and then use paint thinner thinner to wipe off paint, removing the clear finish, allowing the lockset to tarnish/rust.
I might use WD-40 as my solvent to clean out (I know what the others said, but it actually does well here), and then use a quality oil or graphite.
I'd be more inclined to remove the lock from the box, and clean it seperately, lube it, and reinstall it. Sometimes they are riveted though and it might not be practical.
Re: OT-Lock Lube?
I highly doubt that paint thinner was the reason that those locksets tarnished and rusted. If paint thinner could take off a finish that was on there, your skin oils will too. Paint thinner (mineral spirits) is not a very strong solvent, and it does evaporate fairly quick, especially a thin film of it from a rag.
As for the brake parts cleaner, I've used LOTS of it on my vehicles for many different things. It evaporates so quickly that it won't do much to even lesser coatings, never mind today's catalyzed vehicle clear coats.
I said what I did about WD40 because a friend's late father was a gunsmith. Without fail, the worst guns he saw in terms of operation were those that were "cleaned" with WD40 by the owners--because of the sticky residue it leaves behind. Guns and locks have similar mechanisms inside.
Jason (painter by day...)
Re: Try Lock Ease
Larry in nw ohio
I have used bike chain cleaner/lube and it works great. Larry
Re: OT-Lock Lube?
Jason Waters
Vehicle finishes are typically very durable, but I don't use anything on them I don't have to. That's why I suggested removing the lock if possible, and if not, using solvents with caution.
As for the paint thinner, I agree it's not as agreesive as other solvents, but the door I was talking about was the only door painted, and wiped down by the painters, and there was evidence of the clearcoat damage. The other two doors (both exterior as was this one) had the locksets (same brand and type) installed at the same time, and exhibit no of the issues. It may not have been mineral spirits used. In this case, I am almost certain the finish on the lock was removed with a solvent, and I have done it myself on brass hardware with solvents as well.
As to the WD-40, I agree it's terrible for lubing stuff, but I have used it to clean goo (as it drawns out moisture too), and then wiped down and replaced with other oil. It is not lubricating oil. Maybe a CLP (Cleaner Lubricant Preservative) product would be better.
Re: Try Lock Ease
tom
Bike Lube! That I have but I read this post too late and my wife bought the Lock-Ease.
