Cree light color(OT)
Larry in nw ohio
I`m very interested in these cree lighting. The problem I`m having is getting a good color of the light. Can someone tell me how a person can tell the color of the light from what is on the package and what would the color be of an incandesent bulb and the lumens. I`m trying to find something that is close to an 100 to150 watt incandesent. Thank You Larry in NW Ohio
Re: Cree light color(OT)
Re: Cree light color(OT) *LINK*
John McGaw
The color of the light is given in degrees Kelvin. The LED light's specification sheet should be telling you what it is for their product. For incandescent lights you can take your pick: old "standard" incandescents are fairly low temperature while halogen and xenon lights (also incandescent) can be much hotter thus more blue-white. The brightness in lumens should also be given for the LED in the spec sheets while standard bulb packages are required to show their claimed output. For the latter the type of housing reflector or diffuser may have a large effect.
Color Temperature Explained
David Barnett
(Message Deleted by Poster)
Re: LED color temperatures with comparison pics
Roger Rayburn
I know it's hard because I've suffered the same challenge. I ended up just reading the package that my incandescent bulbs came in. It's a bulb that I use enough of and like that I buy several at a time, so the package is already just laying around. On the package are the two most important pieces of information that the above guys are talking about. First is the lumens. That's the amount of light the bulb puts out. If you have an incandescent lamp that you read by that you like, pick that same number of lumens for your purchase. The second is color temperature. On the package somewhere is the color temperature. It is usually a straight line with an arrow pointing to a place on the line and a number at the arrow indicating the temperature in degrees kelvin. The color temperature is what decides if the bulb is "daylight" or "soft" or "bright" or whatever. Again, if things in your room with the lights on are the way you like them, get the package out and see what the color temperature is on the package for that bulb. Forget about watts. Watts are about power consumption and in an incandescent bulb about half the power consumption, maybe more, is wasted on heat, not light. You simply can't compare fluorescent or led lights to incandescent based on watts. Light temperature and lumens gives you a way to compare what you have with what is available.
David Barnett
directionality
Henry (Raleigh NC)
The directionality of LED lights is something I just discovered. I just purchased a LED strip for 'under the cabinet' counter-top illumination, thinking I might replace a clunky fluorescent fixture. The directional down light is fine, but we found the dispersed general light to be less than adequate. This wasn't quite spot lighting, but rather than soft shadows from a long fluorescent bulb, rather harsh shadows were created. I am afraid I will be returning this particular product (18" strip with about 15 LEDs).
Although we live in the heart of CREE territory (headquarters less than 15 miles from here), I have not yet found any retail LED bulb labelled with the CREE name. Which retailers carry their products?
Henry
David Barnett
Jason Roehl in Lafayette, IN
Argh...
Sometimes marketing garbage jumps out at me and sticks in my craw. This phrase was in the description:
"...and pay you every year"
All man-made lighting uses the same amount of energy when they're turned OFF. And, all of them USE energy, which will COST money when they're turned ON. There's no paying going on. That's different from a payback, which, due to lower energy usage, will result in lower energy costs and save money, eventually even covering the initial outlay. Either way, though, it's on the other side of the accounting tables--you'd be reducing outlays, not increasing revenues.
Jason
Re: directionality
Larry in nw ohio
Henry The LED Cree puck lights that I bought, I got from Lowes and they are made by Utilitech. These are & watts and I have 8 in an area that I use to have 15 20 watt. So I went from 300 watts to 56 watts with just about the same light. I like mine. Larry in NW Ohio
Re:Henry
Larry in nw ohio
In that last post of mine, I messed up a little. If you didn`t notice the & is suppose to be 7 watts and where 15 20, that was suppose to be 15- 20watt bulbs. Sorry. If you get some of these to put under a cabinet to shine down on a cabinet top underneath it, I believe you`ll like it. Even with my old eyes it`s a lot of light. Good Luck Larry
Re:Henry
Larry in nw ohio
Henry I just happened to think, just about got a headache, that if you would want to try these lghts, you could try the basic starter set that has the power box /transformer with three lights and try that and see how you like it. Larry
thanks Larry - I saw those there too
Henry (Raleigh, NC)
Larry: I saw those puck lights there too, but having had a poor experience with pucks lights previously, I opted for the LED strip/ I'll go have another look.
How can you tell that Utilitech LEDs are made by CREE? I tried to read the packaging, but did not see that anywhere (or could not read it?!?!)
Henry
Re: thanks Larry - I saw those there too
Larry in nw ohio
Henry I really don`t know if they are made by Cree, but I just call them that because of the little part that creates the light itself. I guess these have been out for a couple of years, I`m guessing that because of what someone said in a post somewhere and that is all I have heard what they were. I have`t heard them called anything else, unless I just didn`t see it. The only place I recall them being made, could you posibly guess where, correct China. Like I said before, if you try the starter pack, I think you would like it. If not you can take it back. They do put out really good light, inmy opinion of course. Larry
