Latest inlay completed
McKay
I have nearly completed the last of the inlays that need to be done. This inlay was for the prototype spice cabinet. I built 7 spice cabinets and this was the first to get started and the last to get the inlay done. I used Honduran redheart, blood wood, some yellow stuff, maple for the flowers. I wanted to have a red breast for the bird so I found some dyed camel bone for the red and green. The wings are bubinga and black palm. The body is maple. I still need to scrape the thing down to the field and then I will use some poly that has UV inhibitor for the surface. I do not care for poly, but it was the only thing that I could find that would help keep the blood wood and redheart red. If UV inhibitor is not used, then the flowers would turn to a yucky brown. Hope that you enjoy.
Re: Latest inlay completed
Yonak
McKay, I like the way you frame the picture with the circle and the way the flowers extend beyond the frame. Nice job.
Bill Tindall, E.TN.
I am always amazed by the pictures made from wood. Curiosity...how did you cut the circle?
If you thin the polyurethane it can wind up looking like about any other finish that builds a film. However, many varieties of it will yellow over time.
Any exterior finish will have UV blocking compounds formulated into the finish. Many of the water based products are acrylic based and these polymers typically do not yellow.
Don't know where you would get them but if you could get a pure UV stabilizer a better approach would be to dissolve it and brush a coating of it onto the wood, then apply the finish over it. You might try calling General Finishes tech service and see if they would sell you a few milligrams. In fact, you might convince them to sell a solution just for this task. I know the chemist there. I'll drop him a note and see what he thinks of the idea.
Bill...
McKay
The circle was cut by the Lie Nielson radius cutter. I was disappointed in the cut that it made in cherry, but with this white oak, the cut was very clean. String inlay is a pain in the back side to make, but it really adds to the project.
strings are tivial to make
Bill Tindall, E.TN.
Just installed 90 feet of them plus another 20' of practice. What part do you find difficult, cutting width or thickness? I may have a fix to make life easy.
The harder the wood the better the LN cuts. Steve Latta told me that some of the cutters had left the factory improperly sharpened. He didn't elaborate on what improper was. The cutter should have needle sharp points on the teeth and be filed like a cross cut saw.
cutting string inlay
McKay
I cut the full thickness of board w/a 1/16" saw blade. That cut is quite easy. I then clamp the 1" wide piece on the work bench and use a #80 scraper to get it to the width of the inlay cut. I then set a 0 clearance board on the saw and a feather board set the thickness of the inlay cut on step one. This cuts ok, but I am not thrilled w/the cut that I have. The results are usable, but the amount waste is big. Finding good clear maple is a chore.
lost beyond step 2
Bill Tindall, E.TN.
" I then set a 0 clearance board on the saw and a feather board set the thickness of the inlay cut on step one." ? are you cutting the height of the string in this step?
I thickness the string on a drum sander. A scraper sizer is easy to make from a card scraper. I can send picture of the Steve Latta version if you wish. Maple scrapes easy. Holly doesn't. Took minutes to make. The cutting board Latta ahs for slicing the strings works great. I mounted an Exacto knife in a marking gauge to do the cutting of the "veneer".
"Finding good clear maple is a chore. " Maple is a common wood. Where are you at that it is not readily available? It is worked so commonly that about any cabinet shop should have it stocked. If you ever get to E. TN I have about 700 bd ft to choose from.
Re: lost beyond step 2
Larry in nw ohio
McCay and bill and anyone else. Where do you get your cutting tools? Or do you make your own. Thanks Larry In NW Ohio
