Planers
Planers
Planers
brian greene
I'm in the market for a new planer in the 12" size category. I'm looking at the DeWalt 734. Can anyone comment on experiences with current machines. This is to replace an existing DeWalt 734, 1998 model, which has given great service. I do know the new machines are three blades versus two for the older ones. My research so far indicates this is also the best priced machine. We are not looking at helical cutterheads.
Thanks
Re: Planers
Re: Planers
Bill Tindall, E.TN.
If you can find an old Delta or Powermatic they are much more robust machines and little on them can break or wear out. They can often be bought for what a new lighter duty planer will cost.
Re: Planers
Definitely...
John in NM
The small Powermatic (PM100) tends to cost more than the Delta/Rockwell 12 and 13 inch planers. All were fine machines and have the advantages of durability and mass over lunchbox planers.
The downside is of course availability. You have to wait for one or travel to get one right when you want or need it. Worth looking around the local CL and other classifieds though, before buying a new one.
Re: Planers
Re: Planers
Robin Corell in Atascadero CA
That Dewalt your thinking about is a nice planer but at 90 lbs its about as portable as a sack of cement. If you didn't mind the lasck of protability of your first planer then you should also consider the vintage heavy duty models Bill mentioned along with the venerable Parks model 95.
Robin
Re: Planers
Re: Planers
Brian Greene
Thanks folks,
This is for a low volume semi-commercial shop. We have been happy with the DeWalt we have and thought we'd replace it with the same machine. I was looking to see if anyone has had any bad experiences with it.
