Kitchen "pantry" or cabinet opinion
We currently have a cabinet in our kitchen that is about 7' or so high.
SWMBO has expressed a desire to have a larger cabinet - "that maybe goes over the refrigerator". This can be done - I can manage to find out where the studs happen to reside.
This got me to thinking - what is the most practicable height for kitchen cabinets as well as the depth. I'm talking a standing cabinet that has no counters. It would be a "L" shape with the arm extending over the refrigerator space.
The existing one is 7' H x ~20" deep x 30" W.
The ceiling height is ~8' - but as I was planning on using crown molding - that makes no real difference. Red oak plywood is available in 8' lengths - and that is what I was planning on using for the sides as well as the shelves.
I'm somewhat inclined to make it 8' H x 23" D x 30" W with another 36" going over the refrigerator space. That would be 23" D x 36" W x about 30" or so from ceiling down. Is that too high or too deep? Obviously access to the upper shelves would be by step stool or equivalent.
TIA
Re: Kitchen "pantry" or cabinet opinion
Some thoughts...
Rod Peterson—Ormond Beach, FL
I built a wall of bookshelves, nominally floor to ceiling, but to eliminate issues with ceiling height, I built the whole thing on a 4" high platform, somewhat shallower (also about 4") than the shelves, and full length, wall to wall. You might be able to adapt that for your project.
A 23" depth over the fridge is going to be deep at that height, but it wouldn't matter if you made it less deep, because you'd still have to deal with the depth of the fridge. All those high (and deep) cabinets are good spots for stock pots, roasting pans, and other equipment which only get used a few times per year. For those, step stool available is perfectly good.
Because you're so deep for each, the floor to ceiling section might be a candidate for a swinging shelf. I built such a project based on a "Fine Homebuilding" blurb several years ago. 30" probably isn't wide enough to do the whole shebang, as I did, but there might be a useful nugget with which to work. Here's a link to the one I built:
http://woodbutcher.net/house/pantry.shtml
There's no such thing as too much storage space in a kitchen. The question is, how to make it useful. You're absolutely right to think about cabinet depth as an issue.
Rod
Dave Bair
I don't have an opinion about cabinet heights. But I'd sure rethink making an "L"-cabinet. It would be one very awkward piece to build and install. I'd go with two separate cabinets (the tall one and the one over the 'fridge) joined as part of the installation with screws through their shared side. As to my cred's: I built and installed all my kitchen cabinets, including a pantry, a peninsula with drawers and doors on 2 sides, and built-in appliances.
A word of caution....
roger lance
you can not stand up an 8' tall cabinet in a room with an 8' ceiling.....design so you will be able to install it.
Point taken
But I'll still just have one piece of crown molding across the front!!
That's why I'm doing crown molding...
I still have to figure on exactly how tall I can make it. I've got some scrap cardboard that I can cut a template out of to see how it might work. By calculation, I can make it 93" tall and I should be able to swing it up. Another thought is to make a plinth for the bottom.
Now you tell me!
Tony - Memphis
I figured that out by accident during the install of my first project for our new house - a set of bookshelves in an odd little space between the master bath and master bedroom. Fortunately, it was an easy fix but a good lesson...and yes, I play an engineer by day!
Something else to conisder, my wife and I are both pygmies and therefore, most everything above the first upper cabinet lower shelf is a stool access only, so for us, that isn't a concern. Good luck with your project.
Tony
Re: Some thoughts...
William Duffield
Rod, a rhetorical question:
From your pictures, it appears that you can close the pantry door with either of the swing-out cabinets open. If you assume you will always close both of the swing-out cabinets before you close the panty door, couldn't you make them twice as deep, thus wasting less space?
Sir William!
At the time I built them, there were plans afoot to build additional "soup" shelves or perhaps roll product dispensers (cling wrap, tin foil, wax paper, parchment) on the doors, which would have taken up much of that space. In practice, we elected not to, and it's probably just as well, as the actual space in which to reach in to the back shelves isn't nearly as commodious as I had envisioned in the original design. It's good enough to get things out as well as to stock shelves, but no two handed operations are possible.
That lack of space would be exacerbated were one to adopt your suggestion, as having stuff on the doors would have impinged even more on that space, unless the doors were fully openable, and they're not. However, if the pantry/doorway/doors were wider, it might be feasible. Really, given what you have observed, the better solution might have been to have deeper back shelves, although we've found them adequate. Still, that vision didn't come until too late to redesign.
Thanks for the thought.
Rod
Rod
make the toe kick seperate
Dick Coers
You can level in the toe kick before the cabinet is set. Then tip up a taller cabinet, and slide it on the toe kick frame. I've always made the toe kick seperate, even on standard cabinets, it makes for an easier install, plus you get better yield from the plywood. You can only get two 34.5" sides from a rip, but 3 ea. 30.5" sides
Myra in TN
I am 'vertically challenged' myself. Over the years I have discovered that a storage space above the fridge is much more accessible if the cabinet has a pull-out shelf instead of just a stationary shelf.
Re: Sir William!
William Duffield
Aha! Without building it, or without your warning, I would probably not have realized the limitation was not a collision between door and shelf, but between the swung open cabinet, the door jamb and the shoulders!
Kneale Brownson
Pullouts are wonderful for deep cabinets
Kneale Brownson
I'd want them for even the lower deep cabinets. It's hard to peer into deep spaces with trifocals and a 73-year-old back.
Our solution . . .
Yonak
This is the solution Ginger and I came up with for the deep cabinet over the refrigerator :
We must use a stool to get to the topmost shelf and to get to items behind the cookbooks.
One thing I would change (and I may still) is to, rather than make both doors the same size, make them meet directly above where the refrigerator doors meet, for consistency's sake. Another consideration : Make sure the ceiling fan is off before opening the doors !
Thanks for the idea.
Re: Our solution . . .
Don in Central Illinois
Thanks, I really like that idea.
Kitchen cabinet build on YouTube.....
roger lance
the Norm Abram kitchen cabinet build can be found on YouTube.....this is a 10 part series and I believe that around part 4 or 5, he gets into building cabinets around the refrigerator.....good info there on making cabinets for a kitchen. Sorry, I can't link you.....but look under New Yankee Workshop, Norm Abram, workshop kitchen cabinets.
Mike Rubes, Apex, NC
Hi Rod,
That is a great design and execution. I agree about never having too much storage space in a kitchen. Great write up as well. Makes me look at the pantry in a new light!
Thanks for the pics/writeup.
Mike
Listening to the rain here in Apex, NC
