Have a question? Ask Woody!
My lighting solution
McKay
I was laying in a dentist's chair and noticed the trolly for the light. I thought that this could be a solution to the problem that I have in putting light where I need to have it. If any of you have ever watched Mathis Wandel, then you may know of an associate of his by the name of Ron Walters. Ron has made a number of shop solutions that you should check out. One of those solutions is a scissor light. I combined the the trolly from a dentist light with the scissor apparatus.
Here is a view of the adjustable light.
Here is a view of the trolly. I bought a cheap skate board, took off the trucks and mounted them up side down on a piece of ply. This is then installed in the trough. The trough is screwed to the ceiling. I used a fairly inexpensive 1 1/4" dowel from Lowe's hardware. I am sure that smaller dia. would work, but I like to over build.
I have a nine foot work bench, so I made the trough long enough to pull the full length of the bench. Works really well.
Hope that you enjoy.
Re: My lighting solution
Another lighting solution.....
roger lance
Keeping with your theme, I mounted this goose neck lamp on a block that runs in a track along the wall behind my lathe....it's simple to move the light along the track to illuminate the area that you're turning.....
need is the mother of invention....or something like that.
Jason Roehl in Lafayette, IN
I like it!
The lazy cheapskate (pun intended!) in me would probably just buy a couple-four sets of bypass closet door track.
Jason
Lars Parrington
pretty awesome!
how do you manage the electrical cord?
Lars
McKay
The power cord for the table saw and power planer come down from the ceiling with the dust exhaust tube. The light cord is tied to these so it is also pretty much out of the way. The cord on the scissors is held in place with electrical staples that allow movement of the cord when extended.
My kinda solution
I love over-the-top solutions like this. You even went a step further with the inlay detailing on the box sides. My only question/concern about this contraption is whether it might need a brace at the top to minimize the dowel's deflecting from the weight of the scissors and lamp.
What a nifty solution.
There is some..
McKay
movement on the light because of the weight, but I put a 3/4" ply washer on the trolly to minimize the movement. The movement that I have observed is minimal. If the movement gets to be more pronounced, I will add more washers or what ever.. to make it continue to function. Vertical adjustment is about 20".
