Routing a rabbet
Ka1imp
I have made a lazy Susan out of 3/4 cherry. I want to rabbet the edge by 1/4 x 1/4 to add some inlay/molding. What is the best way to do that
Routing a rabbet
Ka1imp
Re: Routing a rabbet
2 ways. One is to stick a wasteblock in the center with double stick tape and use a circle cutting jig if you have one. The center pin goes in the waste block.
The other way is to cut circle and glue it down with double stick tape and use that as a guide for a bushing on you router.
How did you cut the circle for your lazy Susan?
If all you want to do is rabbet the edge - a rabbeting bit with a bearing would be the answer. If what you would like to do is cut a dado at some distance from the edge, you've got some "interesting" choices.
My preference - if you can tolerate plugging a hole in the center of the lazy Susan - maybe out of a similar material to your inlay - would be to use a trammel. That way you could use a spiral upcut bit and just go around the piece using the trammel. You would have a neat circular pattern. It might be possible to use a router table - but you would have to make a jig to hold the lazy Susan while you rotated it. Again - I would propose using a spiral upcut bit.
If you are somewhat old fashioned, you could possibly use a series of cutters with a beading tool. You could set the beading tool to a particular distance from the edge and slowly cut the channel. It would take a bit of time. I use a similar method when I cut gutters on chairs - except I usually draw a line and rough cut the gutter with a gouge before I go over to the beading tool.
Ka1imp
I used a carter circle cutting jig on the bandsaw , not perfect . I want to put a small rabbet around the top to install a 1/8 by1/8 beading to off set the color of the cherry
Larry in nw ohio
You got good suggestions from the others so I`ll say something about your bandsaw. You said not perfect, well the bandsaw needs to be "almost" perfect. If you do not know it, the front of your blade, the very front of your tooth needs to be right in line with your pivoit point circle cutting jig, any diviation and your circle is not going to be very good. Good luck with your project. Larry in nw ohio
