Recommendation for drum sander requested
Larry
Looking for a Recommendation for drum sander Capacity 22" plus. Jet ?
Thanks
Larry
Thanks
Re: Recommendation for drum sander requested
HC Sakman
I've a dual drum General 24" which works OK, just need to take light passes. I have used 36" SCM which is 10x more money and yet even that machine does not work 10x better if you compare performance vs cost. Although, SCM can handle much longer steady work hours which is where the real difference is.
Larry
Thanks, for the information. I was looking for a opened design.
Clint Searl
I have an unused Jet Pro 22 44 for sale if you're interested.
Larry
Clint, Where are you locate? I posted this for a friend.
jcousins
i've had the performax 22-44 for many years - use it primarily for cleaning up veneers so use a sled to save the drive belt. it serves it's purpose well as long light passes are made. random orbital or hand sanding is always needed to finish the piece - that's with 120 on the drum. i have found that getting the cantilever arm "dead on" is quite challenging and have learned to live with it a few thousands out on the far end.
jerry
Larry
What is the model number?
Thanks
Clint Searl
Larry, I see by your profile the you're on the left coast. I'm in Eastern PA.
Roger Rayburn
I have an old Delta 18-36 that has proven reliable and seems to hold the table dead flat and keep the arm parallel to the table really well. I don't know if the new ones perform as well or if Delta is still in business, given all the rumors (some of which are 15 years old).
Bob
I bought a Jet Performax 22/44 the only thing I can fault is the digital gage. Mine came off and I will leave it off its a waist of time, As for the machine I have the 3HP and feel its under powered so if I buy again I will get the 5HP. It takes some getting use to loading the paper but once you get the hang of it its a breeze I can change paper in less then 3 min. I ran my work bench on it 4"X12"X7' 1/2 at a time and it did a great job (not recommended) I have ran 30" table tops with no problem. I buy my paper in rolls 300 yards and cut my own belts. OH, learn to use the tool for loading paper it works in spite of what some people may feel.
jcousins
Bob
I have the same machine and fixed the problem after studying it for over a year and scratching my head because I needed it to run my own veneers. I put lock washers behind all the adjusters and torqued them down after I got the outboard set about one and a half thousandths lower then the inboard. Seems to be holding.
I never go below 180 grit (that's what smoothing planes are for) except on veneers which I do use 220 and lower.
Larry in nw ohio
I have had a woodmaster sander for over 10 years and really like it. It`s a very simple machine if and when it would need to be worked on. It would be worth a look. It`s made here in the USA,in Kansas City. Larry in NW Ohio
