Makita Miter Saw...Help Me!
I have no tool money to speak of. Yet, I am unexplainably tempted to buy a Makita LS1216L 12-Inch Dual Slide Compound Miter Saw. I need to be stopped before I do something stupid.
So can anyone who knows this saw give me some good reasons not to buy it??
TIA
Tom
Re: Makita Miter Saw...Help Me!
Jim in Burlington Ont.
Jim in River Oaks, Ont.
Sure..
Get a good quality cross cut saw, learn to sharpen and you will free up some bench space, save some $$, get super clean cuts and get some exercise... yeah... not likely..
Jim
John M in Mid Mich
Don't do it: the 10" has been serving me so well for so long that it would be a huge (2"?) mistake to go for the LS1216L. ;)
HC Sakman
Only God can help you Tommy. Keep the faith.....whatever happens...
Chico
Robin Corell in Atascadero CA
Lack of tool money didn't stop me from buying a tig welder two weeks ago.
As for miter saws. I still have an old school 10" makita non compound chop saw, the one with the big knuckle hinge and cast iron table. I'd upgrade it if I could find the same saw with a 12" capacity.
Robin
No help here
I've had a 12" Makita chop saw for over 15 years and I don't have a single negative thing to say about it. Makita always came out on top in the tool tests we did for various magazines. That was before Festool came out with their saw though. Maybe you should pull the trigger on one of those instead.
Budget, ha!
Jason Waters
What do you need it to accomplish?
I always heard the sliders didn't cut as accurate as the regular miter saws. But that was years ago (when I bought my DeWalt 12").
John in NM
Do you need the extra height the 12" CSMS gives you? As I remember you don't end up with any more cut depth from one, just height. Handy if you're timber framing, but my little 8" Hitachi has been all I ever needed in the shop. Man I wish they still made that saw! Their new one does not get the reviews the original always did.
The Makita has a 15" cross cut. I buy a lot of rough lumber. I cannot tell you how often I get a piece that is 1/2" wider than my current saw can go.
I prefer using a slider for length cutting stock. The TS takes too long to set up for that.
My only beef with the Makita..
Tim Greif - West of Chicago
I have a Makita LS-1220 chop saw, 12", non slider. My only beef is with the fence, which has warped, making it slightly concave. It results in miter cuts that are off by about a half degree. I can't for the life of me figure why, since this is a solid aluminum casting. I first noticed it this year and I've had that saw since 2002. A new casting is over $50. Be sure to check the one you're looking at. When I lay a straight board across the fence, there is a noticeable gap at the center cut line. For now, I've adjusted the fence for a perfect 90 registered off the left fence and I fudge the setting by a half degree when registering off the right fence. Works ok, but still bugs me. Other than that, I really like the saw.
That is wider...
John in NM
Mine only goes to 12" give or take.
Re: No help here
HC Sakman
You are just simply put: "bad to the bone" Ellis...!
Chico...
