Fogging of the glasses fogging is a sign ...
Henry (Raleigh, NC)
My opinion....
Fogging of the glasses fogging is a sign ... that air moves around the mask. If it moves that way on the exhale, it is likely to be able to do on the inhale half of the cycle too. Now I understand that on the inhale cycle the mask will be pulled against your face, but I think the point remains. If air leaks around the mask, doesn't that defeat the whole purpose?
I suspect that these mask certainly provide some level of filtering, and the certainly are better than nothing, but if you are going to bother putting on a dust mask, why not go to a real solution? The half mask respirators are not cheap, but they are also not very expensive. in the long term they are WAY more effective (although I have no 'proof" of that), and in hobbiest use they will last for years.
I couldn't ever recommend a solution like a disposable mask for in shop use - most of us are in this hobby for the long term and a half-mask respirator is definitely a worthwhile investment (< $50??).
Henry
