question for Robin Corell Cratex wheel
Rick snyder
Hello Robin,
Are there cone shaped wheels to match the differsnt size chsiels. When I googled the only thing I found were flat wheels. If thats all the make, how do you use yours?
Thanks, Rick
Re: question for Robin Corell Cratex wheel
Robin Corell in Atascadero CA
I used a tapered wheel but it is not the same size as the insde of the chisel you just use it to polish not shape. Cratex are available in wheels, tapered wheels, and tapered cones, each in several sizes, and I think in four different grits/colors.
Robin
Thomas S Stockton
The woodcarving shop I worked in we used an old coarse file to get them to the shape we wanted. It's really hard on the file so don't use a good one.
Tom
2B6
http://www.cratex.com/rubpoint.htm
There's this too Rick.
I was thinking of shaping one to match the sharping stone for the Morticer chisels. That would hone the inside after using the stone. ;D
Suppose using a grinding wheel dresser would work? I have one of these .....
http://www.woodcraft.com/product/2000223/2793/wheel-dresser-diamond-tip.aspx
