Swing Down Plywood Storage?
Derek Arita
I need to store plywood in a one car garage. The space is so full that the only open space in overhead. It's a typical third car garage with about 2 feet of open space over the garage door, when the door is open. I thought, if I could only build a hinged frame, that i could put plywood on, then swing it up to store. The hinge would be at the header, above the door.
Can this be done? Has anyone done it?
Re: Swing Down Plywood Storage?
You'd need a boat winch or something like that to take the weight of the plywood - I wouldn't recommend just climbing up on a ladder and lowering it yourself, unless you're really fond of the decor, friendly staff, and pleasant company you find in emergency rooms. And you'd want to think about how you built the "box" the plywood was in so it didn't slide off as you lowered it.
And I'd recommend some kind of latch to keep it in place when it's up, even if it seems redundant.
Spend a lot of time thinking about the design. Then spend some more.
But people have done lots of similar things successfully; no reason why you shouldn't be able to.
Consider the proposed
Merle
weight load. If it is typical construction it isn't meant to support a lot of extra weight. If you ask at a lumber store, they should be able to tell you how much weight your garage joists can support. HTH
Hoist up instead *LINK*
Tom Dunlap
This might be a solution, you can replicate the setup using hardware store pieces, you don't need the high grade marine kit.
Tom
Hoist kit
Jesper, Denmark
Re: Hoist up instead
Jesper, Denmark
He is only supporting a couple of light weight kayaks - maybe two sheets of ½ inch ply's worth.
Hoisting several sheets of ply with pulleys requires a much more solid system and some way of adding power to the lift.
I do not have a space problem, but store plywood and other sheet goods vertically against a wall on the short side (< 8 foot ceiling height) The sheets sit on the floor with a lip screwed on the floor, so they cannot slip. There is a 2x4 mounted in the ceiling in front, stícking far enough down, so that you can leaf through the sheets without them falling. The needed sheet is then withdrawn sideways.
Thomas S Stockton
I did something similar for veneer storage, it sounded like a great idea but in reality was a huge pain. It was heavy and hard to sort through stuff. It is also now gone so I wouldn't recommend it. I would take Jesper's advice and store it vertically it really doesn't take up that much room.
Tom
roger lance
I'm reminded of the scene in Jaws where the boat captain says something like...so the cage goes in the water....and the shark is in the water....and you are going in the cage ??.....I'd put bicycles, ladders, yard tools, etc in some type of suspended storage from the ceiling before something as heavy and bulky as sheets of plywood....this just seems like a formula for an accident....how many sheets are you talking about ??....8 sheets of 3/4" only occupies 6" when placed against a wall....you may need a bigger boat.
Derek Arita
LOL!!! That's funny! I really wasn't thinking about storing more than a couple of sheets, plus some remnants, but i'm beginning to think it's more trouble than it's worth to do it safely. Seems pretty cool on paper...hinged at the top, swing down, then swing up to store...but I guess in reality, it's a no deal. I just don't have much floor or wall space, so I was trying to be creative. Right now my plywood is stored against a wall, but I sure could use that wall space for something else...oh well...it was a thought...
Yonak
Derek, according my my calculations, 12 sheets of 3/4" plywood would weigh about half the weight of a queen-sized waterbed. Now, for sure, the weight of the waterbed is spread out across the floor, but all the weight is on the joists while half the weight of the system you're talking is on a vertical structure, direct to a concrete floor. Just make sure you have plenty of stout hinges and they are located closer to the studs than the middle of the header. The other half of the weight could be distributed across all the ceiling joists.
As far as hoisting the weight up, with enough rope and the proper block and tackle, you could pull up the weight and tie it off with relative ease. The biggest stress would probably be the shelf the plywood would rest on when lowered.
I think it's worth further consideration.
Richard McComas
http://www.ehow.com/info_12168575_much-weight-can-hang-roof-truss.html
Joseph Mulherin, sr
Derek, you state that you have a 3 car garage....my question is: why can't you have at least one car space for your woodworking and park the vehicles in the other two??? Do as Jesper states and stand the boards against the wall in his fashion.
Derek Arita
In the one car space is a PM2000, outfeed table, mobile cyclone, 12" jointer/planer, tool box, 20" Jet drill press/mill, Delta 12" radial arm saw, Makita 12" SCMS, MIG welder and rolling miter saw stand with Porter Cable 12" miter saw. Like I said, I'd like to take up less floor and wall space where ever possible. I'm sure I'm not in the minority here. City living is tough sometimes.
Richard McComas
I fix my room problems by parking outside.
