Sommerfld Easy Set Jig
Dave huber
Does anyone have experience with this?
Does it work as advertised?
how big a difference between Summerfeld's and the Freud jig?
How useful are either jig with other brand lock miter bits?
thanks.
Dave
Re: Sommerfld Easy Set Jig
Lester Gillett
Dave i have the Sommerfid jig and it works great with there router bits. They don't work on outher
bits just there's. I know bacause that what happen to me. I had a lockmiter bit from some co, forgit
which one but it didn't work with the jig. If you have all of there bits then its a good one to have.
Lester
Henry Higginbotham
I have one, and while I haven't used it a lot I'd say that it gets you in the ballpark. Sometimes a little better, depending on the bit.
As it happens, I've been fiddling with a CMT lock miter bit over the last week, building jigs and featherboards to get things to work correctly. Sommerfeld seems to have copied the geometry of the CMT bits for their own line of Asian bits, and the lock miter seems to fit. Many other brands wouldn't, some having more shallow profiles or different draft angles (if that term can be applied to a miter bit). However, I suspect that you could still use the jig, along with a little eyeballing, to get the bit height adjusted to center, which is a critical starting point. From there, a straight edge and some patience should finish the job. The twirly thingy that lets you adjust to your stock thickness is a useful feature.
I've also used the jig with Sommerfeld's rail and stile set, and again it got me in the ballpark, leaving me to fine tune things by trial and error. I think it's worth the 20 bucks. YMMV.
A Better jig to set lock miters
Alan in Little Washington (NC)
Oh boy, Oh boy! You guys opened the door!!!!
I have had a lock miter bit for years but never used it. I read all the horror stories about how hard it is to set, most were pretty accurate. But not any more!!!
Forgive my self-promotion, but a few months ago I decided to dig out my bit and attempt to use it on a project (see first two pics). But before I started, I put on my thinking cap. What resulted surprised even me- l designed a neat little (really little) jig specifically for setting lock miter router and shaper bits- any brand, any size!!! It is incredibly simple to use and, unlike my other design, the INCRA I-BOX, this new jig has no moving parts! :)
As a bonus, unlike the very expensive GrooveCenter by Prazi, it doesn't require any special calibration or computation of "sweet spot". You are NOT limited to 3/4" thick stock like with most setup blocks. Also, unlike setup blocks and the Prazi, the halves of the joint can be different thickness! The faceframe can be 3/4" (or any thickness within the range of the bit) and the cabinet sides can be a different thickness- comes in handy especially since "3/4" ply isn't 3/4" these days?. Instead of milling solid wood faceframes to the same thickness as (23/32" etc.) plywood sides, you can use the jig to make a simple adjustment to the bit/fence setup.
As an added bonus my jig will also allow you to easily set the bit and fence to cut "offset lock miters" - there are four additional reference lines that allow you to shift the miter line "around the corner" from 1/16" to 1/4" in 1/16" increments so you can ease, round-over (or chamfer) the sharp mitered corner without having a miter line in the middle of it and without cutting through the surface veneer and exposing the inner plies of plywood sides.
This is NOT vaporware as the saying goes. I have already licensed the design to one of the usual suspects and it is being readied for production now. It should be on the market within a few months!!! (I call it the "Lock Miter Master" but the manufacturer may come up with his own name.)
My project- a bookcase with maple faceframes and plywood box. This pic shows three intersecting lock miter joints. Not too bad?
Lock miter joint between faceframe and bookcase top:
Here are drawings and sample (dry fit) joints made possible with the jig:
Standard lock miter joint:
Faceframe (walnut) thicker than side (poplar):
Faceframe (walnut) thinner than side (poplar):
Offset miter (before rounding):
Awesome Alan !
Don Orr
I'll be on the lookout for that one for sure. Let us know when it is available please.
Re: A Better jig to set lock miters
2B6
That's a pretty good write up. You do ad work for your day job Alan? :)
I've been looking at getting the lock miter joint bit for drawer making & will be using different thickness stock. So were do we look to get one of these set up tools when they come out?
:D :D Thanks. Not an adman just a retired Naval Aviator having fun designing things. Some photos and drawings are from the short introductory email I typically send to potential manufacturers. As you can guess I usually leave out all photos and descriptions of the jig itself, for good reason. Once I have a signed non-disclosure agreement, I follow up with a detailed brochure.
I followed this procedure with my box joint jig (that became the INCRA I-BOX) and other designs as well. I usually start by identifying the problem(s), the current crop of solutions available, where they fall short, and why I think my design is better. Sometimes it works and sometimes it doesn't. In this case I got a solid bite on the second cast! I had a signed licensing agreement in less than two months!
There are always things that can go wrong, so at this point I don't want to identify the manufacturer. It is not INCRA this time but another US company that most know or have heard about. It is being fast-tracked so it really shouldn't be too long before it is released. I have no idea what it will retail for. It is small- about the size of a book of matches!! But it is precision machined. Other than that, I can't say any more.
I'll let everyone know when it is available.
FYI, my first prototype was carefully made from a scrap of wood but worked fine just the same. It was difficult for me to achieve the level of accuracy needed, however, so later prototypes were CNC milled from aluminum and anodized by my brother- they looked pretty slick.
I'll add one additional note- just like any jig that makes it easy for a woodworker to set up a tool or can be used to make precision joints (dovetails, finger joints, lock miters, etc.) directly, my jig will only do wonderful things if the operator is not careless or sloppy when using it.
Whoa, Alan!
If you're not going to be making stuff that's Stupid-Proof and Idiot-Resistant, you best get back to the drawing board!! :D
Re: Whoa, Alan!
You know what they say about people who try to make things that are idiot-proof - they woefully underestimate the ingenuity and tenacity of idiots! :D :D :D
Where
do you think the Darwin Awards come from? ;)
Re: Where
and just so you know- I may live in little Washingon, NC now, but was born and spent my formative years in New Jersey!
Re: Whoa, Alan!
Larry in nw ohio
Alan At work we use to have a saying very simular, "When you make something so an idiot can use it, they`ll just make a better idiot." Larry
Whose bit are you using?
Dick Coers
That face frame picture shows a gap around a lot of the joint. I would expect all the face surfaces to touch to make it a strong joint.
Or,
"It is impossible to foolproof things; the fools just keep getting more creative."
Re: Whose bit are you using?
The photo is deceptive since the joint is just dry fit- no glue, not clamped. The fit is pretty good when assembled for real. It is a 10+ year old Jesada bit. It cuts a really deep relief which gives it a lot of glue surface.
I looked to see if I had a pic of a glued up joint but only found the photo below of another dry fit joint cut with the same bit. It is hard to tell from the angle, but there are no gaps. FYI, this was my first-ever lock miter joint. The bit and fence were set with my first crude prototype jig.
Dave huber
This is good info to know.
i've got a mix of bits. Some are easier to set up than others.
Easier now than before I installed a lift, but the lock mitre bits are a real pain for me. I have avoided using them, anticipating the hassle.
I'll wait to see Alan's mystery thingie I think. I was hoping the Sommerfeld device might solve the problem, and it night. I have other brands. Perhaps I'll get the model dialed in for the Freud bits and see how it goes.
Thanks.
Dave, that is exactly what drove me to design my little jig.
I compare my process to that which happened prior to my box joint jig "Aha" moment. With the lock miter set-up jig, I spent some time closely examining the bit geometry and the inter-relationship between the bit height and fence position. I discovered something about the geometry that, as far as i could tell, no one else had, or at least no one had exploited. It didn't take much design work to figure a way for me to exploit it. Even before I built my first prototype, I was convinced it would work- and it did!! Also, just like what happened during the I-BOX development and testing where I discovered my mechanism increased its capabilities (splined joints), I discovered my lock miter set-up jig would allow the user to easily set the bit and fence for cutting offset lock miters and lock miters in different thicknesses of wood. I don't think any other jig will do that.
Another disclaimer- when they see it most people will likely be surprised at the jig's small size and its apparent simplicity. But it is a precision device and will require good eyesight or glasses when you attempt to match reference marks on the stock with the alignment marks on the jig- I had LASIK and can't see close-up worth a darn anymore, so i wear my safety glasses outfitted with "cheater" lenses when using the jig. 8)
I don't know whether it will appear in the final version, but I wrote this for the draft manual:
"The lock miter joint like many other machine-cut, close-tolerance woodworking joints (dovetails, box joints, etc.) requires accurate cutter and machine set-ups. With these joints, “close” is NOT good enough. The Lock Miter Master makes it easier for you to achieve excellent results, but still requires care during set-up."
