Anybody got under cabinet lighting in the kitchen? I am remodeling a house to sell and put in new cabinets and granite counter tops. I am considering under cabinet lighting to make the granite Pop. Any suggestions? Don't really want halogen puck lights because of the heat. What about LEDs? What do the lights cost? Where to buy them?
Barry I just redid my old puck lights. old 20 watt bulbs that could almost heat the whole house in mid Ohio winters. I replaced them just about a month ago with LED. Not the old style but the new CREE they emit around the 3000 on the color scale, which is about the kind of white of the old incandesent bulbs. I have an area about 15" by 58" and I put 8 in that area to light the cabinet top under them. They cost about $40 for the transformer and 3 lights and about $10 for each extra light. they are called lED Puck lights, and the Item # is354562. I bought these at Lowes. I also got a 10% discount for being in the military. They also have a couple of different kinds. I`m sure other stores would have different kinds. Good Luck, Let us know if you find something different. Larr in NW Ohio
I have two LED strips under my cabinet, a three-light strip and a five-light strip, mounted end-to-end in a single row. Depending on how much light I want when cooking I can turn on just the three-light strip, just the five-light, or both for eight lights. Further, each strip has a dimmer dial, so I can adjust them any way I like.
These were expensive -- ridiculously so -- but they last forever. Those hot halogen pucks worked fine, but never lasted long. I think I paid more replacing those bulbs all the time than I paid for my LED strips.
I got them at one of the Borgs; don't remember which.
I've been looking at using the led strips you can buy in reels. The transformers are inexpensive and you can even get controllers that dim. There are a bunch of them on eBay and Amazon. You might need to make a cover of some sort for a house you plan on selling. I was going to mill a piece of wood and maybe add some sort of diffuser material just to soften the light and make it look nice. They offer nice warm colors of leds (and some wild stuff too!). These things are easy to install and much much cheaper than store-bought. Might be more effort han you are interested in if you are trying to get a house ready to sell though!
I've dealt with these two sources in the past for under/in cabinet lighting. I chose the Xenon thin under cabinet task lights from Pegasus and buy replacement bulbs from Amazon. For overhead cabinets, I picked the Xenon puck lights from Pegasus and Kitchensource. You can also get T4 fluorescent lighting if that suits your needs. Here are the links:
I bought a set of xenon pucks from Pegasus for a bookshelf project. I was very pleased with them as a business and the lights are great. I am using them in a bookshelf to light up art. They work nice and have a nice color for the artwork. Appear to be well made. I can't comment on heat as they are 9 ft in the air and their backs are open to the room. Make sure you pay attention to the transformer capacities. I used two for six lights as I recall. I also added a dimmer. After some resarch, I found there is a special dimmer for transformers. It is pretty expensive, but it works great.
My bride tends to call it "under counter lighting."
We used high-efficacy fluorescent fixtures and put warm white tubes in them. They turned out to stick down below the face fronts of the cabinets by about 1/4"; I intended to put some molding on the bottoms of the face frames to conceal them altogether, but have yet to get around to it, and probably won't, as they're not really noticeable. We were lucky - the fixtures came with rocker switches. The one over the sink (which is on an inside wall) stays on all day, but we leave most of them off most of the time, reaching under to flick one on as we need it.
The tricky part was the wiring rough-in. I had to calculate the height at which the upper cabinets would be and bring out the wiring during the rough-in. It worked out, but I did some worrying until the cabinets went in. Incidentally, I used metal-sheathed cable - I'm not sure if it's required by code, but it should be, as it's exposed on the bottoms of the cabinets.
We installed Xenon fixtures when we did our kitchen.
The fixtures are Kichler brand, purchased locally for less than the price quoted in the link. I'm sure you can find better pricing.
They have a low and hi setting as well as off, though ours are all on one wall switch, and we have them set to the low setting. We have pretty much run these 24/7 since they were installed mid 2006, and though I have a supply of spare bulbs for them I have yet to have to replace one. Even on the low setting they tend to keep our cabinets warm. I would think that LED lights might run cooler, but I've never investigated it.
I presume that when I go upstairs after posting this that all my undercounter light bulbs will have blown:)
