REAL MILK PAINT
So that's how resawing should go!
Stephen Kirk
I got the 1/2" Woodslicer blade for my 14" Jet Deluxe Pro. Popped the blade on, adjusted the guides and such, tightened it as far as it would go, made a drift adjustment then did some test cuts.
Now, with my non- resaw blade, this was a none too good affair, just to level set.
This new blade was like cutting through butter. Almost a perfect 1/8" slice (I was aiming for 3/32, not bad, sanding room). I had some chunks of nameless bits from the firewood pile, about 5" thick. I had some problems with tapering through the cut (from end to end) but that seems related to my feeding and keeping it tight to the fence. Top to bottom looked pretty good. Can't wait to try bigger stock, figure up to 10" oughta be good.
I was worried about getting into marquetry that I couldn't cut my own veneers. A decent blade and even a moderately tuned bandsaw totally changed that. Having the right blade, totally worth it!
Now onto more practice with double bevel technique on the scroll saw.
Re: So that's how resawing should go!
roger lance
I remember well my sense of amazement when I changed out the stock blade that came with my bandsaw for a well regarded after-market blade.....what a difference.
Ain't that fun?!
Bruce, a MN Galoot
I came back from a trip with a chunk of live oak firewood and introduced Mr. Firewood to Mr. Woodslicer. What a batch of flecks! I'm still looking for the right project, but that blade will make them possible.
A more frugal solution
Bill Tindall, E.TN.
I don't have any problem resawing with a 3/4" 3 tpi blade I get made at Misenheimer saw shop. They cost about $11 for my 20" Delta.
Dull blades and too many teeth are a common cause of poor resawing results.
scrollsaw
Charles Yawn
"Now onto more practice with double bevel technique on the scroll saw. "
Let us know how that works, too.
Charles
Re: A more frugal solution
Stephen Kirk
And I thought $30 for the Woodslicer was a decent price. I'll have to remember that shop when this one dulls.
Definitely agree on too many teeth, dull blade causing. 14" saw, 1 1/4 horse motor certainly sees the benefit of a sharp blade.
Re: scrollsaw
Stephen Kirk
I've done some little practice pieces and it's gone we'll. I'm using the "thick veneer" at 3/32" and the double bevel technique. I got David Marks video on the subject and he goes into good detail and moves at an easy to follow pace. The toughest parts for me are making good, tight turns and cutting with the table beveled. Really just practice for those two things. I'm using a 2/0 skip tooth blade, quite a fine cut.
Now I'm working on making some of my own drawings (and this starts with a book on how to draw!).
One thing I like about marquetry is that it's a relatively quiet, easy process. It's not rushed, sometimes you have to slow down to do it well. It's a nice change of pace.
