THE WOODRAT IS BACK!
Drawer Slide Fitment Help...
Derek Arita
OK...so I admit it...I made the drawers about 1/16" narrower than they needed to be, to fit the full extension slides. I thought that maybe the slides would "stretch" to fill the gap, but more consideration told me that it might be better to use shims. So, what can I use to fill the gap?
Re: Drawer Slide Fitment Help...
David Barnett
(Message Deleted by Poster)
Re: I've never heard drawer slides...
Larry in nw ohio
I just finished a couple 4 drawer chest of drawers for my 2 granddaughters and made the drawers a little narrow and I made shims for them to fit better. They work just fine, or am I not quite understanding what your saying. Larry In nw Ohio
John McGaw
You aren't then only one who has done that. The best solution I've found personally is thin washers between the metal and the wood. They have proven to be completely invisible in my applications. I guess that one could, with a bit of guile, veneer both sides of a drawer and make the whole problem invisible but, face it, who actually studies how drawer slides fit as long as they work smoothly?
John in NM
I usually use thick veneer or cardboard from a 6 pack to shim. I don't remember ever buiding something perfect enough that the slides don't need any shimming at all. I'm sure someone, somewhere has done so, but it sure isn't me :D
I usually hang the drawer boxes, then make the fronts fit the opening and attach them to the boxes after hanging them.
Richard McComas
What John McGaw said, I've done that a few time myself. Works well.
Better a bit too narrow than a bit wide. Shims will work fine. I glue them onto the wood under the slide. Some slides have what appears to be tabs that might adjust for this circumstance.
Dick Coers
Type or model of slide would help a lot. Accuride and others made full extension slides that had 3 sided tabs in the center of the cabinet component with screw holes in them. Those are made to bend out and make up for narrow drawers.
Dan
I just had to do this in the last week or so. I also used some tiny washers (perhaps #8) to get the drawers to fit. DB
