Splintering and tear out with router cut
I'm trying to use a pattern bit on some "fairly" straight grained ash. I'm trying to turn a curve and make some legs that look somewhat like a lower case f.
My problem is that I'm getting splintering and tear out. I've blown two legs completely. I've got a pattern - so I'm using a straight pattern bit.
My thought is to put a larger bearing on the top of the bit. This would allow me to sneak up on the pattern. I suppose I could try climb cutting - but I've still got to do the curves.
Any other suggestions?
Re: Splintering and tear out with router cut
del schisler
sound's like you are using a router table ? There are also spiral bits that have both upcut and downcut spirals, these are used to provide almost perfect edges on the top and bottom of the wood ,also go log into this web site it is the router forms, it is all about router's and working with them, i have been a member for yrs, lot's of information on this http://www.routerforums.com/
Read the grain
Lee Schierer McKean, PA
It is very common for two wing type router bits to produce tear out and splintering when the tip of the cutting edge hits the end of the grain at a 70-90 degree angle. You can sometimes solve this by sneaking up on the cut but even that will produce some degree of tear out. Climb cutting is usually the better way to go. However you don't want to climb cut the entire piece. Before you start you need to read the grain to be cut and any place the cutting edge is going to hit the end of the grain or tend to be lifting the grain mark with chalk and climb cut those areas. Cut all the remaining areas using conventional cutting. Just remember that climb cutting will tend to self feed so be sure your work is secured so it can't move and that you have a firm grip on the router.
Lee
Welcome to hand tools.....
roger lance
ash has a tendency to splinter.....you may only be able to use the router/pattern bit on certain portions of the leg and then have to switch over to hand work to finish the areas where you are having the most problems.
I've found a pattern spiral bit - a bit pricy - but so are most carbide bits.
I'll see if it is in the budget.
Jesse Cloud
Here's an alternative to climb cutting - which can be dangerous.
Make two identical patterns. Leave a couple inches of horn - extra length on your workpiece. Put one pattern on the bottom and one on top, careful align them. Get a long piece of dowel and find a drill bit thats a snug fit. Drill a hole through each horn, with the patterns on, stick the dowel thru the hole and cut flush.
What you now have is a sandwich that you can flip over, allowing you to cut in both directions. Based on the grain, mark the direction of cut on each pattern and flip as needed. No climbing required.
Works especially well in a production environment.
Use a larger diameter bit
Dick Coers
I assume you are using 1/2" diameter? I use the 1 1/4" diameter pattern bit, 1/2" shank from Freud and it makes a remarkable difference. They make up to a 2" diameter. Rough cut on the bandsaw closer to the pattern so you only have 1/8" or less of wood with the remove on the router. In some cases, you will have to "whittle" away at an area by staying off the bearing for the first cut, then a final pass against the bearing.
