Grind your own cutters
Bob
Does anyone grind there own router bit cutters? Where do you buy your blanks?
Bob
No, but...
John in NM
I've used some un-balanced router bits before... horrible!
I think I'll stick with commercial bits
Agreed
I have used HSS to make lathe tools - those I can and do grind. I have used HSS and steel to make scratch stock - those I can and do grind. I have made chisels and tools (blacksmithing work) - helps to have access to a blacksmith who teaches quite well.
I don't think I could do an adequate job of symmetrical grinding without the proper tools - which are probably quite expensive and would see little use.
A source for tool steel bit blanks is MSC. I buy tool steel from them for lathe tools - they might have what you want.
Re: Grind your own cutters
I really don't think it is feasible to do in any woodworking shop. I even have a Boyer Schultz surface grinder and would no more attempt to make a balanced cutter than I would try to make my own grinding wheels. First I use very few HSS router bits. I would rather use a Harbor freight carbide bit than the best HSS steel bit on the market. To braze, fit inserts and balance the bit would require more equipment than anyone could justify for their own use. (and I do have Oxy/acetylene torches. Even HSS would have to be properly hardened (or pre-hardened and wet ground). I do "touch up sharpening" with a diamond tool on my bits occasionally. There are too many other ways to spend my time in the shop - Bits are really pretty inexpensive when you figure in the time they last.
Point taken.
I have altered some,
Keith Newton
But I usually try to start with something close to my desired shape first.
A better way to make your own cutters, is to use a shaper. There are several kinds of heads which can hold the cutter steel. These heads are pretty expensive, and so are the blanks, not counting the time to grind, balance, get them set in the head, is more costly than having one made.
I have, on occasion
I don't necessarily recommend this, but I've done it. I once had to duplicate a thumbnail molding profile for a repair to an original 18th century paneling job. Normally, I would send an accurate drawing of the profile to my custom bit grinding jobber and get a carbide bit within a week, but, since I didn't think I would ever have further use for this profile, I decided to grind it myself. I bought a big flat tool steel blank bit, laid out the profile on both flutes, and ground them on assorted grinders until they were as good as I could get them. The bit actually worked very well, with no perceptible balance issues. I only needed a couple running feet of this molding, and this was easier than making a molding plane for the occasion.
Larry in nw ohio
Bob There are a few places, most any place that handle router bits, thar will make special cutters. RidgeCarbidetool.com comes to mind for one. I think they do excellent work on saw blades. Their phone is 800-443-0992. Larry in NW Ohio
Re: I have altered some,
Bob
I wish I had the use of a shaper. I would do it in a heart beat.
Re: Grind your own cutters- Thanks Ellis & Larry
Bob
I'll give them a call to see if they will make some from my grawing.
Another custom vendor *LINK*
John in NM
I found them when looking to get a custom bit made - a simple 7/8" ball cutter - and found they already had them in stock. So I've never tried their custom service but have now used several of their stock bits with no complaints.
Magnate Carbide
Bob, what is the size and shape you need?
Keith Newton
If you could post a drawing or piece of something you are trying to duplicate, there might be some combinations of other bits that could get you there.
Inquiring minds.
