Resaw blade, 1/2 or 3/4 on Jet 14" Deluxe
Stephen Kirk
I'm starting to make my own veneers. I want to pick up the Woodslicer blade that now comes in 3/4", as well as the 1/2". Does getting the 3/4" blade gain me anything, or might there be problems tensioning it? The Jet 14" Deluxe is rated to 3/4" max blade width. Price is negligible between the two blades.
Btw, using the stock 1/2" 6 tpi blade yields some pretty poor results. Slow and prone to burning.
Re: Resaw blade, 1/2 or 3/4 on Jet 14" Deluxe
Brian in SLO
The Woodslicer 1/2" is a good blade for the 14" bandsaw. The 3/4" is too much blade to tension, as you suspected. I have the 1/2" Woodslicer and have been nothing but happy with it for resawing.
I know there are some other blades out there others might recommend but the Woodslicer is right up there with the others.
Re: math
Lars Parrington
i have both 1/2" and 3/4" woodslicer for my 14" delta, but have never put the 3/4" on. the 1/2" lives on the saw.
as i understand it, what matters is the cross-sectional area of the blade.
a typical 3/4" blade is .032" thick --> area = 0.0240 in^2
woodslicer is .022" thick --> area = 0.0165 in^2
a typical 1/2" blade is .025" thick --> area = 0.0125 in^2
if your saw struggles to tension a 1/2" blade, it will struggle a bit more with the 3/4" woodslicer, but not anywhere near as much as with a regular 3/4" blade.
Larry in nw ohio
Stephen I have an old 12" Craftsman Bandsaw from about 35 years ago and for just out of couriousity I bought a 3/4' blade for it. I was able to just get it on and it worked very well. I didn` need to tension it just a lot but it took just enough and it seemed to work fairly well. I do use it once in awhile when I really need to, better than having to buy another saw. Larry in NW ohio
