computer problem with "coupon"
Jerry Gibbs
I have this annoying "coupon" on my computer. It may be malware. Questions about this problem suggest I am not alone. I have Kaspersky and have run a full scan, but the problem has not gone away. Thanks. Jerry
Re: computer problem with "coupon"
Rick in WNC
I have had good results with a software called MalWareBytes you can download a trial version from www.malwarebytes.org, install update and do a full scan.
Jerry Gibbs
Thanks. Malwarebytes did not seem to help. Jerry
Doug in Utah
Does it come up when you start your computer? If so, look in your start-up folder to see if there is a program related to it. (Run | msconfig | Startup) [Assuming PC, not Mac]
Chuck in Mtl.
How or when does this coupon appear on your computer?
characteristics
Jerry Gibbs
Problem first appeared maybe a week or 2 ago. A small coupon would appear and say this site has a coupon. I could get rid of the coupon and indicate that I did not want a coupon for this site. Now a blank coupon appears immediately upon accessing the internet through internet explorer and yahoo. I cannot get rid of the "coupon". I am running windows 8. I have run a Kaspersky scan and a Malwarebytes scan. Jerry
Re: characteristics
Larry in nw ohio
Jerry Did you try and go back and reset your computer to before you had this problem, I don`t know what you call it, but you set your computer to before a problem started. Maybe it may be called Restore. It always worked for me. Larry in NW Ohio
Stuart Johnson
Have you tried a "free" trial copy of anything recently? If so this could be what is causing the coupon. If you delete it you might fix the problem.
Re: characteristics
Chuck in Mtl.
It sounds like you are describing popups?
I would like to suggest you try firefox as your browser and see if the problem remains.
To me it seems like there may be a setting in IE that should be tried.
Re: characteristics
Jerry Gibbs
also when I try to close out the is an error message re "MerchantD"
Stuart Hough
Jerry, I want to first state that I am definitely NOT a computer wiz, but I have gotten several of those types of things over the years. They are embedded in a lot of otherwise safe sites, due to jerks and crooks. I tried everything you did, until I called McAfee, my anti-virus supplier, and was told about the "Restore" procedure. This will probably be the best, fastest way to disable it. It won't be eilminated, because it will remain on the hard drive, but it won't be recognized as valid anymore. You will have to choose a Restore Point that is earlier than the first time you saw the popup, and it will take several minutes for the process to run, but you should be good to go after it finishes. And as always, the first thing to do afterwards is run a full, deep scan with your chosen antivirus program. You might find it can be eliminated, or at least quarantined, so it will never bother you again. Good luck.
Re: characteristics
Chuck in Mtl.
do you have a merchant google account or similar. i quickly googled the merchantD and it suggests the problem lies in a google account that you may have. Also have you tried deleting all the cookies in the browser? Look in the options tab and you should find it.
Add-on possibly *LINK*
Bill Howatt
Sometimes this type of stuff gets loaded as an add-on in your browser and can be killed by disabling it.
http://windows.microsoft.com/en-CA/internet-explorer/manage-add-ons#ie=ie-8
In Windows 8 I get the impression there are actually 2 instances of the browser available - one from the "Metro" start page interface and one from the Desktip interface. So you may need to do whatever in the appropriate or both browsers. Do they both exhibit the problem? I say this because I had to enter my online banking login info separately.
Bill
Manage Add-Ons Link
Windows 8 navigation
Jerry Gibbs
The link you referenced said go to start and then select all programs. When I select start there is not option that I can find for all programs. A page full of icons comes up with various programs. I admit I am new to Windows 8. Jerry
Spybot has always
Merle
worked for me, but I haven't encountered your MerchantD coupon. It might be worth a try.
Lee Schierer McKean, PA
I would switch to Firefox as a browser, as it has far fewer problems than MS Explorer and there is a popup add on for Firefox that seems to work very well. Stay away from "Chrome" also, it seems to be advertiser heavy with lots of annoying popups.
Lee
Re: Windows 8 navigation
Bill Howatt
Look near the upper right corner of the MS site. There should be a drop-down box and you want to select Internet Explorer 10. This may help if you were looking at the instructions for an earlier version.
Bill
Think I found it.
Jerry Gibbs
There was an error message when I tried to close all tabs. The error referred to a url about yahoo coupons. I went to that site and was able to disable the coupons. The coupons were not working correctly, since a more or less blank coupon would immediately come up, block part of the page and could not be deleted. Anyway it appears to have gone away. Thanks for the suggestions.
is pop-up blocker on ?
del schisler
i belive yahoo has been up dateing their site? lot's of sneekey things taking place , good luck
kurt
If you really want to control what is permitted on your browser, there are a few FireFox add-ons that are useful. I use 3. One is called adblocker, another is called ghostery and the third is called noscript. Noscript can be a bit of a pain when first using it. A great many things on some web pages will not work until you allow scripts to run permitting third party embedded web sites. You can choose to always allow, allow this time only or not ever. I was amazed at the amount of crap that gets loaded when I visited a site like NFL.com.
