Thinking about plane blades and chisels, I've had an eye on this thing for a while. It gets darn good reviews at Amazon, but I've never gotten close enough to see one.
I'm wondering what attachments are worthwhile and which are not-so-good. Also, it consumes PSA sandpaper, so are there better types to get or places to get it from?
Just looking for experience from the group -- not trying to generate heat over alternative sharpening methods.
I bought one a few years ago and found out it just wasn`t for what I needed. I haven`t really used it, and would like to sell it if you want one, let me know. Larry in NWOhio
A while back I attended a sharpening demonstration. They had a Work Sharp, a Tormek and a variety of other means of sharpening. Everyone got to try each of the available means.
Of the machines, the Tormek gave the best and most consistent edge. While it was a bit futzy in using all the jigs, it was rated the best. Of course it cost more than twice what the Work Sharp did. Now Tormek has the T3 model which is less expensive - so you may want to look at that.
But to directly address your question - you might want the tool bar attachment and the wide blade jig.
If you do lathe work, you'd want those attachments. You also may consider getting some Tormek parts or Jet parts as they fit the Tool bar attachment. I'm talking the Tormek Multi Jig, the tool rest and a few other things.
It really depends on how confident you are on keeping a bevel. If you are fairly confident - you won't need many attachments.
As far as PSA sand paper - go for Norton or Klingspor. Buy extra crepe sticks to clean the sand paper.
I'm not knocking the Work Sharp - it is a reasonable tool. I prefer others, but I have a couple of friends who swear by the Work Sharp.
. . . not for getting a working edge, I mostly use it in place of the bench grinder before honing by hand. That's just my preference and it couldn't be easier to turn the thing on and stick a chisel in for a few seconds. One of my former (and soon to be returning shopmates) was using it for all of his sharpening. We had four grits set up on two discs and could get a pretty good edge in a short period of time. It's a good machine, great for basic stuff and while not fool-proof it is very fool resistant.
I don't go through a lot of paper so I just pick up the Worksharp stuff when I'm at the local store, if I remember and if they have it in stock. With the coarser grits and my limited use it's not unreasonable.
I'm not into gizmos, some I've tried and some I haven't. Everything I've seen has been well thought out and engineered. I would start with just the basic machine and see what you think of it. One thing I did like was a slotted disc that you can see through as it spins, I liked that a lot for carving gouges because I could see what was happening as it happened.
I am considering buying a WS or a Tormek also, just looking for the right deal. I have a MKII honing guide, and it works OK, but can be tiresome when trying to hone a consistent angle every time, despite the angle gauge being used.
As for the PSA problem, I don't spend the extra $$ on special PSA disks. Instead, I use plain sandpaper cut to size and adhered with rubber cement.
I've had one a couple of years and I like it. It is really, really easy to use. I'm really lazy and sharpening is not something I want to spend time on. I can sit at my bench and sharpen / hone every chisel and blade in my arsenal in a really short period of time or I can just touch up the one I'm using in just a few seconds with no learning curve refresh. The real result is that I'm more likely to keep those tools sharp than procrastinate.
Having said that, I don't have the lathe tool attachments for it so I can't comment on their value. I go to an auto body paint store for my PSA paper. It's a lot cheaper than anyplace else and they carry the "polishing grits".
