Where to buy 3 dozen drawerslides?
Doug in Utah
Where would you suggest I find some cheap, 35 lb load, drawer slides? Not for furniture, I just need some more low-end shop drawers. Maybe you know of a good supplier that is not well known?
Re: Where to buy 3 dozen drawerslides?
Re: Where to buy 3 dozen drawerslides? *LINK*
Stuart Johnson
You might try here. I've purchased from them twice with good delivery.
drawer slides
Larry in nw ohio
When I need Drawer slides, I usually get them from www.cshardware.com, they have some good prices or you might try Amazon. Larry in NW Ohio
Doug in Utah
Wow. Two very good links to cheap slides. Thank you.
However, I am pretty ignorant about drawer slides so I have some basic questions.
It seems there are two types: The cheap 'white epoxy type' (which can be bottom or side mount) generally under $4.00, and the more expensive side-mount roller bearing type, which are around $8.00 and up.
It seems that the white epoxy type needs to have a carcass that matches the depth of the slide which attaches to the back., and the side-mount type could be less than the carcass depth since they are not attached to the back.
Do they come in pairs? All the pictures show just a left mount and quantity 1.
What is meant by "2 mm push-rebound"?
If my drawer is 24" front to back what lengths can I use? For example, could I use a 20" full-extension and have a drawer that opens only 20" which would be equivalent to a non-full-extension?
I know—too many questions, so I'll stop and see what response I get to these.
Please educate me!
Stuart Johnson
I know Cabinet Anything's come in pairs but check other sources to be certain.
I'm not certain but it could mean the width of the drawer must be within 2 mm of the specs. For example from the web site: CLEARANCE REQUIRED FROM
DRAWER BOX CABINET SIDE: 1/2" + 1/32 - 0
I don't think it would be a problem if installed on the front of the drawer and cabinet.
Bob Lang
No idea what "push rebound" means either. I can't imagine anyone selling lefts only, but sometimes when you buy in bulk there are separate boxes for each of the four components (L & R for both the drawer and the cabinet). Wouldn't hurt to ask. Also figure in the cost of shipping, a local supplier to cabinet shops might be a better deal overall.
The tolerances side-to-side are tighter than 2mm and the key is a square drawer and a square box to put the drawer in.
If at all possible, figure out a way to mount the slides to the sides of the box, not the back, unless you really enjoy sticking your head in a dark hole to line things up. The lengths of the slides don't need to match the depth of the drawers exactly. If the box is longer than the slides you'll lose some extension, and the opposite is also true. Slides a few inches longer than the box depth will function more like full extension slides. On a typical kitchen base cabinet, using the bottom mount epoxy slides, I would use 22" slides and a 20" box.
--Bob Lang
David Hay Denver
eBay is another good source. That's where I bought quite a few full extension slides for some shop cabinets I built.
David
RogerInColorado
If you have a Habitat for Humanity outlet (aka Re-Store) you should check it out. Sometimes they have bunches, sometimes they don't. If they don't you might find some inexpensive stock to build the drawers so you have more for slides. Or you might find some drawers already made that you can use.
