I was at the local lumber yard last week and they had some samples of Douglas Fir 5/4 stock on the counter. It was in the rough and they are sell it at $1 per bd. ft..
I was wondering if anyone here has used this wood for any type of furniture? What type of finishing did you do?
I love the appearance of quartersawn douglas fir (vertical grain fir). I hate working with douglas fir - splintery and hard to sand evenly, but the appearance of vertical grain fir is wonderful - very composed and refined.
I wouldn't bother with flatsawn fir - the beauty just isn't there for me.
vg doug fir is just beautiful - but as mentioned it splinters - when you cut it use some backer pieces to avoid end breaks. it finishes to a nice mellow orange'sh/beige/yellow. if it's vg for $1/bf it would be a good deal.
Splintering can be an understatement. I've had a growth ring almost separate and actually run in front of the router. Climb cut or sneak up on edge work with a router. I do love the color also, but it can vary quite a bit between boards. If the furniture color is critical, the rough sawn sure won't help you with that. Also, be careful of lumber yard material that is kiln dried. That might mean 20%, with variation between boards. Let it acclimate before working.
Not all doug fir is created equal. I have seen anywhee from 3 rings per inch to 10 rings per inch in what is commonly available in most yards. I also have some salvaged old growth with over 100 rings per inch, yes you read that correctly one hundred rings per inch. as you can imagine the working properties of these extreames vary as widely as their apearance.
I too like the color which can vary from a pink to a mellow amber, most will mellow with age and even KD or very old stock will still exude a bit of resin once opend up. I made some doors out of some staves from some 80 year old marachino cherry vats made out of doug fir. The staves were about 10/4 thick and I milled them down to 7/4 and they all exuded some resin droplets.
As others have mentioned it is brittle and prone to edge splintering. this makes fine joinery very challenging. it finishes well but I have never liked the way it takes a stain so I prefer the natural color.
I don't think of it as a furniture wood but I suppose you could use it as an inferior substitute for souther yellow pine in any of the styles commonly made with it.
In reply to your actual questio of whether anyone has used it for furniture and what type of finish, I have used it to make several "school desks" for home schooled children of aquaintances of mine, including 2 of my own children and a grandson.
Due to the pieces needing a rugged finish (children can be rough on furniture) I used several coats of poly followed by a final hand buffing with wax (to get rid of the last little dust nibs that always land on a finish).
As for opinion about the wood, yes it is splintery, but it also is a very nice looking wood if it is quartersawn. I was fortunate to be in the right place at the right time and was given for free several hundred BF of 4/4 and 5/4 pieces from 8' to 12' long. A local university was replacing its old basketball seating with new and was trashing the old lumber.
I'm looking at a chopping block table I make ~15 yrs ago (first or second furniture project) - didn't have a planer or jointer at the time, so I bought a piece of maple countertop, 4x4 hemlock for the legs, and cvg fir aprons and shelf. There is tear out where I drilled the holes for the dowels that hold the shelf boards, but since those spots are covered with stock pots, I'm the only one that knows. It still looks good, if I do say so myself.
In general, the CVG stuff looks great, but I remember it being pretty spendy. The peeling grain is definitely a problem - climb cut when you can safely, and I would avoid doing much in the way of edge treatment with the router in any case.
