7 1/4" blade for tablesaw
Lars Parrington
there was some talk in a recent thread about the merits of using 7.25" blades in a tablesaw. i do this sometimes and kinda like it, but my only 7.25" blade is cheap and doesn't leave the greatest surface. so, anyone have a recommendation for a good 7.25" blade for use in a tablesaw? i'm looking for a combination blade, preferably one with some flat raker teeth.
i own a couple ridge carbide blades and have been quite happy with them. they have a 24 tooth 7.25" for $50 which is tempting except it seems a bit thick at 3/32".
Re: 7 1/4" blade for tablesaw
David Barnett
(Message Deleted by Poster)
good choice
Good to see these blades catching on. They have vastly less stored rotational energy so they are not inclined to throw stuff. "Don't try this at home" but for demos I start the rip cut in a small piece of lumber and then let go it it. Usually it just sits there till I stop the demonstration. At most it wiggles a bit and slides away from the saw.
I have been using these CMT blades for several years and there is none better. As good is the Stehle #20-15779. The Tenryu blades have not done well in my hands.
For an 8" blade I like the Freud Avanti 40t ATB. the paint has worn off it but it has 07007091-27-08 stamped on it. I tried a 71/2" Freud of some kind at a Freud demo and like it too but no idea of the number.
In general go for an industrial quality 40T combination blade. These blades can be sharpened once or twice for about $10.
Please sxplain
Gary Smyth
"...but what really wins me over is the the flat-bottomed kerf from the CMT which works nicely for thin feathers on small boxes and drawers."
When you say feathers what do you mean? Is this like a thin outer edge left intact to bend as are the Northwest Cedar boxes? Or, perhaps a whisper thin edge that is sanded away that prevents tear out at a mitered corner? I can't wrap my thoughts around what your feather is (used for).
Re: Please sxplain
Andy Lincoln,in Dearborn MI
Gary,
I am going to assume that what David meant by feathers would be similardecorative splines/key used in joining boxes.
I found a quick image on Google that is representative.
They're not just decorative
I mean, they are pretty in the right application, but they add some cross-grain strength to the joint, too.
I like them and have used them several times. Traditional hand-tool feathers are a handsaw kerf wide and can be used not just on boxes but on mitered frames such as picture frames.
Re: My first choice—CMT's 7¼"x 40 1FTG+4ATB
Tom Pilsbury (Chicago)
David, the CMT sounds like a good blade. I like the flat bottom kerf feature. But what about a splitter? I don't think I could use the standard blade guard/splitter/pawl device on my 10" Jet TS. What do you do?
David Barnett
David Barnett
Re: GRR-Ripper® with home built splitters
Thanks for the informative response Dave. I've seen a lot of good reports about the Grr-ripper and one of these days I'll take the plunge and buy one. I'm keeping an eye out on Craigslist. And I have a few extra zero clearance inserts for the TS so I'll reserve one for the thinner blade and add a homemade splitter. Thanks again.
I don't use a splitter
These small blades have no tendency to throw pieces so I have not had any need to worry about installing a splitter for this blade. However, if one had the need to be ripping thin stock a splitter is helpful to keep the teeth from dragging on the outfeed side of the blade. If anyone has the need to rip thin stuff these blades will be a most welcome discovery.
Re: 7 1/4" blade for tablesaw *LINK*
Lars Parrington
thanks for the recommendations guys. i think I will go with a CMT blade. it looks like there is also an 8-1/4" version available for about the same price. interestingly, the grind is slightly different:
7-1/4" blade -- CMT 251.040.07 -- 1FTG+4/20°ATB -- 0.071" kerf
8-1/4" blade -- CMT 251.040.08 -- 1FTG+2/15°ATB -- 0.075" kerf
any thoughts between the two?
http://www.amazon.com/gp/product/B000P4JPIY/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Thanks, David for the article
Dale Lenz
I do a lot of keyed miters in my flag cases and will try a few suggestions in the article.
David Barnett
same experience here
I have an 8" Freud but rarely use it in spite of the fact that it seems to do just fine. If I am doing a lot of heavy ripping a 10" rip blade gets installed. But for routine stuff the 7 1/2 stays on the saw. After you use the 7 1/2 for a while a 10" blade seems terrifying by comparison.
David Barnett
Not to start something here, but
Bruce, a MN Galoot
A Sawstop's main selling point has little, if anything, to do with kickbacks.
David Barnett
MN nice?
Bruce, a MN Galoot
We had ice followed by snow today, so not feeling up to it.
I'm interested in the little saw blades, though. My contractor saw is an old 9"' and I like the narrow, flat-bottom kerf. How deep will that cut tipped over for a miter? I do recall Bill T showing me the blades he used in St Paul. I shoulda been more observant.
Some experience
My son had a 7-1/4" blade mounted in the Makita jobsite saw he gave me. I really need to replace it, as it's getting a little dull. I've cut through a 2"x4" at an angle, I think it was about 60 degrees, with plenty of blade. Have yet to run into a problem with lack of depth, but I'm running carpentry stuff, not furniture.
It's an 8" saw, so I may get an 8" replacement blade - I think he was saving money, not following Bill Tindall's safety lead, in mounting the smaller blade. But that's not as dramatic a size difference as 7-1/4" to 10", so the safety issues won't be dramatic.
David Barnett
60.  60?!  Hah!
Bruce, a MN Galoot
We don't even close our bedroom windows until the temp hits 40. :D
I shoulda 'splained
Bruce, a MN Galoot
I like to make boxes, and it's really handy to use just one saw set-up to cut the sides to length, lower the blade and cut a slot for a spline. That way I can dial in the angle and not worry about it. It's really nice to have a flat-bottom slot for the spline.
flat bottoms, splines and missed opportunity
Here, of all places, the opportunity to use a chisel to pare the spline bottom flat is being avoided! At least if you are using a machine, the machine should provide the opportunity to use a hand tool. What can I say :) ......
Re: 60.  60?!  Hah!  *LINK*
Life in Minnesota
