Re: Electrical problem
Gary
Dave, I believe you already got your answer, but this is for clarification. When the saw is initially turned on the motor will draw more current for a very brief moment, until it gets up to speed. This is true for all electric motors. Normally this shouldn't blow the fuse, however the coldness is most likely causing more stiffness in the moving parts of your motor. Belts are stiffer, lubrication more viscous, tolerances between motor shaft and bearings tighter. This all means the motor works harder and will initially draw even more current just to get started. I suspect the normal initial current surge is close to the 15 amps, but in the cold it's drawing just slightly more than 15 amps and blows the fuse.
As mentioned, changing to a 20 amp fuse should do the trick, but make sure your wiring/outlet can handle this (whatever the electrical code is for 20 amp service). Hope this helps.
