Any Cree lighting experts here
Larry in nw ohio
I`m very interested in this cree lighting, like what is the element made of, and how can a person tell how bright a certain fixture would be compared to an incondesent bulb. What kind of wattage would you have to get to compare to a 100 watt. Thank you. Larry
Re: Any Cree lighting experts here
Re: Cree lighting
Not an expert, but I have one and own some stock in the company.
The "element" you ask about is one or more LEDs that are composed of different chemicals depending on color spectrum and output.
Every unit is rated in terms of "lumens", i.e. the amount of light output. Incandescents, halogens, and fluorescents are similarly rated. CREEs are usually set up to run as low wattage (up to 16w) on 110 or half that on 220. Any fixture you look at with have those ratings on it, so that is what you can use for your comparisons.
CREEs will also have color temp. statements from 2400K (warm) through 5600K (daylight) and I've seen some in the 7000 range which is quite blue.
hth
Why not call Cree? *LINK*
Gary Smyth
If you want technical info why not go to the source?
US Toll Free: 866-924-3645
http://www.cree.com.contact
