sealing wood/which would you use? 2nd half of Q.
Mark M.
This is the other part of my question since I'm not sure yet how to edit. Would this product work (Uni-Gard -50 Uni-Proof Anti-Freeze) for what I'm trying to achieve, it's sold by Holm depo?
Re: sealing wood/which would you use? 2nd half of Q.
Re: sealing wood/which would you use? 2nd half of  *LINK*
Larry Barrett
Although preventing checking in end-grain, which is what you are hoping to do, is problematic, as you have seen in other posts, one of the products frequently used is Anchorseal.
I have used this with some success. I have not used the product you are asking about.
Anchorseal
Robin Corell in Atascadero CA
It will work to a degree. You will end up with fewer to no cracks, but the stuff will continue to leach out and it will cause all kinds of problems with your applied finish. PEG also can have the same issue. pentacryl has the best results for being able to work with the wood once the water hads been replaced.
Robin
