chisel storage
Harry Walls
Looking for plans for chisel storage. Storage I can make out of wood. I
have to get them out of thebottom of the drawer.
Harry
chisel storage
Harry Walls
Harry
Ron Harper posted his chisel solution *LINK*
Bruce, a MN Galoot
on the Handtools Forum
Ron's chisel rack
(Message Deleted by Poster)
I vote for drawers
In my old shop, I had a bank of shallow drawers that might have been used in a sewing store or something. The drawers were a perfect way to organize my chisels. I just cut a piece of carpeting for the bottom of each drawer and stored my chisels there, organized by style and function. I kept spokeshaves in one drawer, too.
In my new shop, I have far fewer tools, but I still keep my chisels and layout tools in shallow drawers, right behind my bench under my back bench. Works for me.
Ellis Walentine, Host
Re: chisel storage *LINK*
Gary Smyth
Check out the link. Dozens of ideas. My preference is to keep the chisel edges DOWN protected by a thin wood fender so an errant hand doesn't cause red to appear. I also use carpet underlayment, industrial felt, or rubber backed carpet on which the edges rest. A light coating of mineral oil where the edges rest protect against moisture exposure problems should there be any.
https://www.google.com/search?q=chisel+storage,+images&hl=en&tbo=u&tbm=isch&source=univ&sa=X&ei=3XXzUMqwNYqH0QHcmIDACg&ved=0CDQQsAQ&biw=1024&bih=571
Re: That one makes me uneasy
Bruce, a MN Galoot
I store mine edge down in a rack on the door of my wall cabinet, but Ron's is one idea to start with. His rack is portable; mine is not. We all make trade-offs. In my next shop I will have more room, and the chisels are going into shallow drawers.
Re: Ron Harper posted his chisel solution
Tim Caley
He also commented that he plans to keep this rack up higher on the wall so that he has to reach up to get them. So he felt the danger from the points being up was not as great as if it were lower on the wall.
Re: I vote for drawers
Robin Corell in Atascadero CA
Gerstner style boxes are perfect for this style of storage, I have two such boxes.
Robin
On the bench and in a rack
Opening a drawer to fetch a chisel while engaged in chiseling operations is inconvenient. This compact arrangement is both an alternative to having chisels in use rolling about the bench and storing those not in active use. I built it after a couple in use fell off the bench. Rarely used chisles can live anywhere, for example drawer. It also holds marking knife and gauge and I intend to add small square storage.
Re: chisel storage
Bob
If you have a bench make a rack you can hang them in and attach it to the side.
Re: chisel storage
JMOHNIKE
Here is another vote for drawers. You can protect the edges by making a sheath from old levi pant legs and hot glue. They work good and are very handy if you ever have to take them to a job site.
Re: chisel storage
William Duffield
Here are two of mine:
I have other chisels and gouges that I keep in drawers, but the moveable racks are for the ones I use most often.
The Hand Tool Forum is the place to go for advise on this subject.
Re: chisel storage
You guys don't have enough tools.
I have to store mine in drawers because they take up too much room other wise. I have a drawer for chisels, knives of various types and then another large drawer for carving chisels. That one is too full and I'm thinking about building a what I'll call a cutting tool drawer cabinet. It will have drawers for everything from Draw knives and spoke shaves to chip carving knives. I'll also include drawers for rasps and other types of wood removeal tools as well as a drawer for my angle grinder tools and cutters. If it's large enough I may also include the Dremel and Flex shaft tool machines and tools.
Re: chisel storage
Phil
My solution: hang'em on the wall (with or without the cabinet)
