Rub for TX smoked brisket..needed
Smoked a brisket today- 4 hr smoke, seal, 4 hr 225 F oven. Meat was fine except it needed some pizzazz which I believe is provided by rub.
During the last step, the oven, a cup of meat juice came out and was floating about in the aluminum foil sealed container. Normal, preventable? Would be better if it stayed in the meat.
Re: Rub for TX smoked brisket..needed
Jason Roehl in Lafayette, IN
Well, water boils at 212ºF, so I try not to exceed that temperature when smoking. The one exception is ribs, which need to go into a higher temperature to render the fat.
I think brisket lends itself to savory flavors, if that helps. The last time I did one, I probably either pulled something off the web or did some seat-of-the-pants seasoning. I also like vinegar--helps break down the meat fibers in tough cuts (like brisket). I would add a few tablespoons to the foil before it goes in the oven.
Jason
Robin Corell in Atascadero CA
You can sometimes get a lot of flavor by changing up the wood you use. Oak, hickory, and pecan all give a nice smoky flavor but they lack that pizazz you mentioned. Mesquite adds a ton of flavor and is well know for bbq and smoking but my favorite is olive wood, both of these will give you a bit of pizazz.
Robin
Dean Johnson
http://www.thesmokering.com/forum/
All kinds of info on brisket and such....
Derek Arita
Well...this is weird...a smoking question on a woodworking forum? Oh well...
Most experts say salt and pepper, 275* till internal reaches about 160*...foil with broth, then back in till internal reaches about 195* and start checking for probe tenderness...but I'm sure you know all that. I'm not a purist, so besides salt and pepper, I use some rib rub which is heavy on garlic, but again, experts say no sweet on brisket.
