OT Epoxy and Cloth Weight?
tom
I don't know if anyone might know but here it goes! I am going to build some bike cases. I plan to use 1/4" plwood and coat it with fiberglass cloth and epoxy.
Would anyone have an idea of how much this would weight per 12" x12"? I cknow this is a long shot but I thought I would ask!
BTW I have asked about these cases on a few previous posts. But am now at the point of finally starting.
Thanks for any info!
Re: OT Epoxy and Cloth Weight?
TomD
The basic number can be reached by just doubling it. I also save offcuts as they form a basis for real numbers which can vary for many reasons.
So if you use say 4 oz, you will need to look at 8 ounce, but that is per square yard, normally, so you are probably looking at an ounce per square foot. This number is the glass and epoxy, with the weave fully filled. Filling weave is a highly variable process, since it can simply keep layering higher. Or one could do second coats with bog. Saving some weight. The numbers do not count the initial saturation coat, but that would probably be say 2 ounces a square foot, but varies hugely with epoxy, ply, temp, etc...
Glass has two main functions, one is to help build the thickness of the epoxy coat. This is in order to reduce transpiration, which may not be all that critical in your panniers. Another is toughness, like scratches. Normally stiffness is more efficiently gained with wood, and stiffness is normally the governing factor, though you can decide otherwise. Of course at the corners, the grass is joinery. For these reasons I made panniers for my mother's bike and glassed only the corners in many cases.
Don Stephan
Out of curiosity, will the plywood try to curl if the fiberglas and epoxy are only applied to one side?
Robin Corell in Atascadero CA
As you probably know the weight of the cloth is the actuall weight for 1 square yard. the weight of the finishd lamination has a huge number of variables. One of the biggsst is whether or not you are doing a hand laid/rolled application, or if you will be using a vacume bag. You can get much lighter and stronger results by using a vacume bag and the same set up for veneering can be used for epoxy laminating.
The most efficient lay up scedule may not require the same amount of cloth over the whole structure i.e. one layer of 6 oz on the inside and 2 on the outside with the corners havinge several layers of tape inside and out. I'm not suggesting this is a suatable scedule just that you may have widely different amounts of cloth in some areas.
If you vacume your lay up you can use some standard figures for estimating weight, with hand lay up all bets are off.
Robin
You don't have to have cloth on both sides but the ply does need to be encapsulated in epoxy or you will get warpage. Most people lay up at least a thin layer of cloth on the inside for protection against scratches and scuffs.
Robin
Re: Be Aware......
Howard Acheson
... that epoxy resin does not stand up when exposed long term to the UV in sunlight. It will rather quickly begin to get cloudy and then crack and loose adhesion. Water will get into the substrate through the cracks and cause further damage.
For exterior protection, epoxied items like canoes and other marine items are coated with an exterior rated varnish that contains UV inhibitors. The best is Epifanes which is only available at true marine supply stores. Stay away from big boxes as there so-called exterior polys and almost worthly. Like epoxy, poly is quickly attacked by the UV in sunlight. The most protective and long lasting treatment is to use an opaque paint which completely blocks the UV.
Re: Be Aware......
tom
Robin, Your coomment about using a vac bag set up has me thinking. I do have a 4"x8" bag set up. What suggestions would you have to keep from making a mess of the interior of the bag?
Jesper, Denmark
Jesper, Denmark
Cloth by itself does not have very good peel strength when laminated with either epoxy or polyester. Start by filleting the inside corners - a tongue depressor is a good tool. Remove any ridges from the filletting and use one layer of mat and one layer of cloth. It is very convenient to use Visqueen as a means to smooth out the lay-up. it does not stick to the epoxy and gives an easy way the squeeze the epoxy into the lay-up and geta smooth surface in one go.
If you do the inside first, you can then rout all the outside edges with a 1/8 inch round-over bit, as the inside fillets will keep things together. lay-up the outside the same way and then finish with epoxy, thickened with a light weight filler to get smooth.
Paint with either UV protecting varnish or pigmented paint to eliminate UV exposure to the epoxy.
An alternate to plywood is structural foam, such as the stuff used for boat construction - not polystyrene, as it will not hold up to the epoxy.
Re: Be Aware......
I have only done hand laid glass but from the reading I have done vacuming is the way to go for maximum strength and a by product of that is lower weight. I'm sure ther is probably a forum that could give you the kind of help that is available here for making things with wood. sory I can't be more helpfull.
Robin
tom
Because I am planning to use aluminum extrusions for the corners and the lid to box connection I will not be filleting. I don't know but I am not sure that using epoxy/cloth all around would be strong enough.
Ralph Lipeles
It won't weight too much. Epoxy and glass are used in making strip canoes which are designed to be very light.
If your not goimg to glass the corners there is no point in using it for the panels. Someone else expalind how to fillet the inside corners and then using a router on the outside forners before glassing them. Done correctly this would get you a stroger part then using the aluminum extrusions.
Robin
Jesper, Denmark
Jesper, Denmark
I totally agree. The fillet and glass is much stronger than alu angles and screws.
tom
Well maybe I will reconssider and only use the Aluminum Extrusions for joining the case and lid together.
Re: Be Aware......
TomD
On the UV, that is 100% correct. However a bike kept indoors will last a long type with nothing over it. I also made bamboo fenders and coated them only with epoxy, and they work great also. A bike used for say touring, may be stored indoors, and obviously when touring there is never any sunlight, and it always rains. Net result is decades of worry free use.
Re: Be Aware......
TomD
"I have only done hand laid glass but from the reading I have done vacuming is the way to go for maximum strength and a by product of that is lower weight. I'm sure ther is probably a forum that could give you the kind of help that is available here for making things with wood."
There is not doubt that vac bagging is a better way of doing things, but the clutter and complexity factor in comparison to the weight saved is so low in this kind of application, that it would probably not be worth doing. It is still possible to build boats today using conventional wood epoxy construction that fly right through a field of high tech composite boats. Recently I saw an ad in sail or some similar magazine for a new carbon fiber trimaran made in foam and carbon fiber, at astronomical cost. It was 2 feet shorter than my tri, and narrower, it did weight a lot less maybe 25%, but it probably cost 10-20 times more than mine cost to build. Simply vac bagging skins will save only a few percent in weight, and will hardly be worth it.
It is often said that vac bagging is stronger, and it will save weight, improve composite quality, and improve strength to weight, but adding vac bagging to a plan that did not initially call for it can make a weaker composite. The reason being that less epoxy is present, and often dimensions get pressed down a little which is critical to stiffness and strength. Of course a completely new schedule and design could be drawn up, and would be more efficient. I am merely pointing out that adding vac bagging to a process not designed for it can make the product less effective.
TomD
"If your not goimg to glass the corners there is no point in using it for the panels. Someone else expalind how to fillet the inside corners and then using a router on the outside forners before glassing them. Done correctly this would get you a stroger part then using the aluminum extrusions. "
Very sound advice. I would just add that one does not need stuff to be stronger than strong enough, and beyond that, one can select other factors.
TomD
"Out of curiosity, will the plywood try to curl if the fiberglas and epoxy are only applied to one side? "
Normally not. Lots of curl with a piece of solid wood, you have built a scale hygrometer, but plywood is normally dimensionally stable. Many boats only have the glass on the outside. Though long hard experience has taught me that maintenance normally dictates some glass on both sides. There would only be rare occasion where one glassed on sides of the ply then did not even epoxy seal the other. And as I say at least some glass is normally worth it.
