Not 100% OT: Name this mechanism
Henry Higginbotham
Not completely OT because I need to make an articulated arm using 2x4s or similar, and have them stay locked in position.
Usually you see this type of spline already cast into the end of some specialty part, like the one shown below. But I'm hoping that someone makes the same gizmo as a pair of big, mating washers with holes for fasteners. That would let me join whatever I needed.
The problem is, I don't seem to have a close-enough idea of what it's called to be able to do a search for it. I've browsed through the Reid Tool catalog and a couple other places without success. Surely it's got a name. Anyone know?
Re: Not 100% OT: Name this mechanism
Brad Chenoweth
Henry,
Do a Google search for "serrated locking plates". At first look, that seems to be what you want.
Brad
Ralph Lipeles
If you are not supporting too much weight you could try making then out of hardwood with sandpaper glued to one of the faces.
Larry in nw ohio
Henry I don`t know if what I found will work for you but it may be a start. In the McMaster carr catalog they have some srrrated washers and a vibration-resistant locks that may give you an idea. Good Luck. Larry
Split-ring connectors *LINK*
I've used split ring connectors to join large staircase stringers to landings, and they make a ridiculously strong joint. They're easy to install using just a circle cutter.
Split ring connector
Are they adjustable?
Henry Higginbotham
I've never seen these, and so far can't fix it in my mind just how they work. Can you repeatedly change the angle between the timbers?
A bit more info on what I'm trying to do might be in order. I want to build a larger version of an indicator base, such as a machinist would use. But the end needs to support a 1/4 HP motor with a buffer pad or wire brush so that it can be positioned against a round workpiece mounted to a slow-moving turntable. Since I have no idea what I might want to polish six months from now, I need good positioning flexibility, and good weight support.
So these split ring connectors might work, if they're adjustable. Brad I think hit it on the nose with "serrated locking plates," but what I'm finding of these online seems to be either U.S. suppliers expecting me to be Westinghouse or General Motors, or Chinese companies who may or may not have actually made any before, but who would be glad to try if I'd place the minimum order of six Panamax container shiploads.
NO help but
Gary Smyth
about a year ago I was looking for something similar. I found two names (lost to me now) (both sold by Alibaba) of a maker from China. I found out nothing. You might have better luck than me. I hunted all over for an adjustable desktop stand to find someone to call with no joy! These are plastic and will "hold" 40 pounds. There were plenty of pictures but after several months I found no answer or even a reply to my emails. These are sawtooth pawls with a push button release. I couldn't find them. Also, antique drafting tables had these mechanisms to adjust tilt that were released by a wheel or a "T" handle. So to were heavy duty TV camera tripods which used knurled knob to torque it down. I found no joy there (around here) as companies like K&E, Quickset, Bogen and ITE are scarce. Maybe the guys in photography can find you a soirce or company that still uses these lock downs. If you find them post the source.
Rethinking
Unless you're using way seriously arms and a huge joint, you might find the weight of the motor results in some "bounce" as it works.
Would it work to have a flexible joint - just a hole drilled through two members, or maybe better yet a variation of a bridle joint through drilled to accept a bolt and nut - and an arm, pivoted at its attachment to one of the members, and running in a hole with a set screw at the other? This would create a triangle that might be stronger than the serrated locking washers.
If this explanation isn't clear, I can try making a drawing.
Yes, but...
... it's not like loosening a wing nut and rotating a serrated connector. With split-ring connectors, you use a circle cutter to cut mating circular slots in the mating surfaces of your timbers (or arms or whatever you want to call them in this application). Then enlarge the center holes for whatever size bolt you want to use. I used 1/2" or 3/4" bolts with the 4" connectors. When you tighten the center bolt through the assembled joint, it wedges the connector tightly into the slots, preventing the two members from rotating relative to each other. To disassemble and reposition the joint, you'd simply remove the bolt and pry the members apart. You could probably incorporate a couple notches in one of the members so you could get a pry bar in there. It wouldn't be the kind of thing you'd want to do every day, but, if as you say you'd want to change the angle only infrequently, it wouldn't be too much of a hassle.
Mock one up and see.
If you're thinking of something that size, *LINK*
Bruce, a MN Galoot
I'd recommend that you post your inquiry on a machinist board such as Home Shop Machinist. They do this kinda stuff all the time.
HSM
Thanks
Henry Higginbotham
Some good answers and alternatives here. Knowing the name of what I'm looking for is a big help, of course, and this project may get re-thought a time or two before I move ahead with it.
Re: One more possibility
Al Stokka - Cambridge, Iowa
Henry,
At McMaster-Carr'a web site (www.mcmaster.com), search for
serrated bellville". These are conical washers with (or without) serrations on one(or both) sides.
It's up to you how to secure them to your 2 x 4's. Epoxy?
Al
