LAGUNA 2HP DC CFM DISCREPANCY...
Derek Arita
When I purchased my Laguna 2hp DC from Rockler, their tech info said that the machine was rated at 1600cfm. Compared with the JDS at 1700cfm, there was little difference. At a lower cost and added features, I went with the Laguna. After the DC was assembled and tested, I took a look at the machine on the Laguna site and found that they had it listed at 1450cfm. I then checked the manual and it said the machine was rated at 1600cfm. I called Laguna to informed them of the discrepancy and find out which was correct. They said they'd call me back after investigating the issue...they never did call back. I called again, got the same answer, but no call back.
If, in fact, the Laguna is rated at 1450cfm and had I know that from the start, I might have gone with the JDS unit, even at the higher cost. If you're trying to make the same decision that I was faced with, beware that the 1600cfm rating on the Rockler site and in the manual, may not be correct. By the way, Woodcraft has it rated at 1450cfm. Sure wish i knew the correct number...just for info sake. If I posted this here before, please accept my apology.
