how do I find?
Gary Smyth
A 3 1/2" steel hemisphere. I need to drill a hole centered on the top of the half sphere. The tolerance is such that I can't eyeball where I think the hole ought to be. By what method do I find the center?
how do I find?
Gary Smyth
Re: how do I find?
Just speculating here...
You know the diameter. Make yourself a circle that diameter out of 1/4" something, using a divider or pencil compass so that the center of your circle is marked (by the divider/compass point). Drill a hole the right diameter for your marking implement (pencil, Sharpie, center punch; not clear what the hemisphere is made from). Take something flexible enough to bend into that circle, but stiff enough to stand up, and cut a strip the circumference of the circle and 2" wide (half the diameter plus the 1/4" thickness of your circle). Wrap this strip around the hemisphere and cinch it tight - hose clamp or something similar. Nestle the circle into the cylinder you've just made, and, once it's all level and solid, mark through your center hole.
Or: if you've got a good drill press and a circle cutter, hole saw the exact right diameter, 3-1/2" Forstner bit, etc., drill a shallow depression in a block of wood clamped to your drill press table; then, without moving the table, rest the hemisphere in the depression and use whatever drill bit you need to drill your hole.
Re: how do I find?
Bill Howatt
It seems to me the location is the very top of the sphere or in other words, the highest point regardless of what direction it is approached from.
Mount a dial indicator gauge over the sphere such that the end of the gauge shaft is near the eye-balled top. Move the sphere around such that the maximum gauge deflection is observed. This point is the very top of the sphere.
I think that would work. Now, you have to figure out how to mark it.
Bill
Tried with a fly cutter and
Gary Smyth
after several tweeks once the hole was cut, fit the base of the hemi into that hole. Problem is, with taking the fly cutter out of the drill press and installing a metal bit I couldn't keep all three -- drill head, the table, and the cutout locked down and stationary. I'm sure I'm close and I may have to use that method but maybe a math formula to find and mark the center before getting it to the table?
Played with 1.75" but my dial caliper
Gary Smyth
legs aren't long enough to reach the center. Tried stretching a cloth tape measure but couldn't be certain I was directly over the center. Those little marks never quite ended up at the same place.
Center Finder *LINK*
http://littlemachineshop.com/products/product_view.php?ProductID=2747
Re: how do I find?
Yonak
How about cutting a 3 1/2" hole in a piece of plywood, clamp the plywood on your drill press so that the hole is centered beneath the drill, then set the dome in the hole ?
Re: how do I find?
Walta
It will be hard drill on the peak of that dome. The drill will want to slide off to one side or the other.
Before you drill, mark your center with a punch.
I would do this on a lathe put the dome in a chuck so dome rotates and drill first contacts the inside of the spear your bit will be stationary in the tail stock.
Walta
Re: how do I find?
Robin Corell in Atascadero CA
You don't actually need to Find the center to drill a hole in the center. First clamp a piece of MDF on the drill press table and with a brad point bit in the chuck and the motor running make a very slight mark with just the very point of the bit. Now using a pair of good dividers set to the exact radius draw a circle using the mark you just made as the center. Now attach a scrap piecce of 1x2 with one edge tangent to the circle and then using a square attach a second scrap tangent to the circle and 90* to the first board. Now if you place your hemisphere against both boards you will drill a hole in the exact center. If you use a center bit there is no need to make a mark with a punch. a center bit will not dance around in a drill press.
Robin
Flexible ruler.
Just run some tape over the thing from side to side. cut the tape off right at the bottom of each side. Peel this off and measure it and mark the middle. Then put it back on and scratch a line. Then do the same thing 90 degrees from the first one. I use this method when I need to divide curved pieces into a known number of slices. I can work out the spacing on the tape.
that's how I do it on my Mill
But then my mill has a sliding table. If you have sliding compound table to put on your drill press it could be done the same way. I purchased one of those for about $80 years ago and it's been really handy at times when I need to do some really precise drilling or even some precision routing.
This seems to be the most reliable method
But you might try just putting a drop of oil in the bottom. If the rim is level it will run to the center, then mark with a punch.
Thanks for the thoughts and suggestions
Gary Smyth
The item left here about fifteen minutes ago. What I did encompasses many of your thoughts. I used what I had and didn't have to buy anything. First of all I dumped the idea of the hemisphere's insertion into a 3 1/2" hole or bracing it so as to be immobile.
First, I took all of the sacrificial wood off of my drill press table and leveled it out locking and supporting it so that it didn't move. I inserted a 5/8" metal bit (one of my longest straight bits) and with a drafting 60/30 triangle checked that it was perpendicular to the table from all locations. With this check I found I had to tweek the drill head very slightly which changed the configuration barely but the relationship between the bit and table is now correct. I took out the large bit and inserted a metalworker's hardened scribe into the chuck. Checked to see that it ran true. I ran the quill down to where I eyeballed the top of the hemisphere to be and raised it a hair and locked it. I put a drop of machinist's blue marking fluid on the top of the hemi. Now there is only one freedom of movement and because it is a hemisphere there is only one point where it is the top. Took the hemisphere, put it on the table open side down, and moving it by hand passed it under the locked down scribe. I adjusted until moving the top under the scribe made a whisper of a line in the marking fluid. I rotated the hemisphere and repeated -- several passes. It turns out the table or more likely the bottom of the hemisphere was not perfectly flat or the scribe perfectly true. There was a variation in the center point at the top of the hemisphere of slightly over one mm. I marked the center point inside the scribe marks, punched it using a different scribe point. Inserted a #52 wire drill in the drill press (the smallest diameter that can be held by my chuck to make a pilot hole. Unlocked everything and drilled the hole. Inserted a piece of heavy thread to clean out the hole and told my neighbor to come pick it up when it's convenient. In a storm he's been here and gone and happy. I learned a bit. Thanks to all. Addendum: Snow 2" to 4" hah. I have 6" on the ground and I can't see anything but white, white ground/sky, no horizon beyond 50 yards.
Another idea for you
Make a simple little gauge block with a cantilevered pin. It doesn't really matter if the pin point is exactly on the center of the hemisphere, because when you rotate the block around the sphere, it's going to scribe a tiny circle. The center of the circle will be your center point. Should be easy enough to eyeball by then.
Re: how do I find?
Barry
Mount the hemisphere in a 4-jaw chuck with the appropriate jaws and drill it on your lathe. It shouldn't be that hard.
Find a metal lathe
Pete in Holland, MI
Chuck it in a metal lathe, start the hole with a center drill, finish with a standard drill.
Dead straight !
