I'm looking for something to get for myself that costs $50 or lets say less than a $100. What have you got in your tool assortment, that if you broke it or lost it you would not hesitate to buy again? Maybe something sort of unusual that has not disappointed you or was better than you thought it might be. Maybe a left handed tape measure? (Why are all the commonly available one backwards anyway?) Or a really fine screw driver? Or a marking gauge? Just looking to give myself a little Christmas present.
While I don't have one, I find myself wishing I had a 4" dial caliper every time I take my 6" caliper in a store. While I can stuff the 6" caliper case in my back pocket, it's bulky and awkward, so I have my eye on the Lee Valley 4-incher. Santa, are you listening?
But hardly any of it would surprise you, being routine stuff. I can think of a couple surprises though, first is this little Japanese stud finder I bought from GW years ago before they sold out to "dumb crap tool co". It's just a little push thing with a small pin in it. Works really well, though after a good decade of use the pin is pretty bent up.
Second is a crummy 9.6V Makita circular saw. That thing was a remodelers dream because it ran so slow that you could cut sanded plaster with a cheap Oldham blade on it and it never got dull. I cut in tons of remodel boxes with that thing before it finally died (I think it got thrown in a fit of pique, so it's not the tool's fault ) Around 2000 or so you could find those little saws in every pawn shop and used tool store, usually for $20 because everyone wanted the new 5.5" 18V ones.
I'd be curious as well, what tool in that price range would we not buy again? I would have to go look through the shop, I need the visual reminder before I say "Why in the heck did I buy that thing?"
I would replace my pocket knife. It's made by Schlieper in Germany. Blades are some alloy that sharpen and discolor like plain steel but don't freckle with rust the way 1095 steel does.
Starrett 4" double square, hardened head, 4R rule (8ths, 16ths, 32nds, 64ths) with satin chrome finish (I have a lot of trouble reading the rule with the regular finish), and, optionally, a center finding head to fit. The center finding head doubles as a saddle square, so it's useful even if you don't have a lathe. I've lost my square more than once, and needed to immediately replace it.
I usually grab my rule and slide it in my back pocket absentmindedly right after turning on the lights. I would be absolutely lost without it.
I have replaced two tools in the past with exact replacements.
The first was my 6" Brown and Sharpe dial caliper with a silver 0 - .100" dial after I dropped my old one on the floor. Its not that I think that B&S makes the best caliper but that I was so used to the dial on my old one that other models just looked funny.
The other tool I replaced imidiatley was my spyderco stainless handled delica II pocket knife when I misplaced it. Several years later I found my original and I am even happier now that I know I have a back up to a tool that means so much to me.
I made a list several months ago for a "remote" away from home "to be included package". While I don't always take all, I at least consider. These mostly small items I would miss/reach for/buy immediately. Included are:
1. Exacto knife w lots of #11 blades
2. stainless steel 6” 45 and 60/30 triangles
3. 2hp mini compressor (what guns and nozzles I might need)
More useful than I ever expected when I bought my set of four at a show several years ago. Quick and accurate for holding parts square while you "put a brad in it till the glue sets."
They've gone up a bit, naturally. I think I paid $45 for a set of four, and now I believe they're around $60.
And to fill out your C-note a bit, the Vaughan Mini Bear Saw, no. BS150D. Not the easiest tool to find, but it's the sweetest-cutting little Japanese saw I've ever picked up. No affiliation or experience with this seller; it's just the first I found with the correct picture. Unless you're less ham-fisted than I am, get a few extra blades--they're brittle and thin.
Now that I've had one I don't WANT to live without it. I could loose one of anything else and get by. But if I lost that I'd be on the phone BEFORE I started looking for it.
Dremel tool without a doubt, I have used it to remove screws, fix small defects (correcting a shape that has a nick etc.) sanding the inside of small holes and shapes, re-cutting screwdriver slot in old screws etc. Polishing brass or cleaning old hinges. I use the darn thing so often it is seldom put up in the box.
Steve (and Dave): What tasks do with a saddle square that make it so indispensible? I agree that a saddle square is useful, especially for laying out tenon shoulders. I have found some work-arounds. First, as I noted in my previous post on this thread, a center finder head does the job. They are a little too narrow to work efficiently, but I have them laying around for turning tasks, so I use them. Also, a Brusso hinge is machined accurately enough to do the job (but it might not save you any money over the Veritas square). It will also work on an edge that is not 90°, and will save you money over the Bridge City equivalent. If I'm laying out with a striking knife (as opposed to a pencil), I find a steel double square or combination square works just as well as a saddle square, and might even be a little quicker. After striking the shoulder on one face, I rotate the stock, find the end of the knife mark with the knife blade, sliding it along the aris, then slide the square up against the knife, and strike the next face. I find this to be very accurate.
I'm sure there are other tasks you are using your saddle squares for that I'm missing. I do use a dovetail gauge, which is just a modified saddle square, for its intended purpose, with a pencil or pen.
If I'm making thirty of the same part (lets say itty bitty 4cm x 4cm x 4cm ammo boxes for model Abrams tanks), I re-saw a 4 x 4 cm stick two feet long. I use drafting dividers to mark 4cm (with small gaps) the length of the stick. I cut my sections just like a loaf of bread. Now, with my LV Saddle square, I've got two sides marked and I can but them on the bench sander and sand the ends of each one square. Regardless of the part I get "square end" markings on each part with one pass of my marking tool. With a traditional square I have to mark one side then go back and mark the other (all along hoping I lined up both lines). It just cuts marking time in half. And making LOTS of the same part.
I had gone to look for it out of brief curiosity and not found it. I think I searched "drywall" instead of "stud" because it only works in drywall (and one has to be a bit careful with search terms like "stud" on the internet )
As a side note, I found GW's website to be better than the last time I visited, which had to be at least 6-7 years ago. Looks like they've moved back to a lot of real tools and supplies in inventory, and perhaps less of the hokey junk. I may have to look around there more often.
Jeeze, I was just being funny. I use mine to build sub-one-gram (200 - 500 mg) indoor model airplanes. But will need them soon for even reading measuring devices.
I am afraid the weight of those loupes would kill the bridge of my nose and create headaches in about an hour. Flip lenses never worked for me. Better suited to blinders, I guess. I pay gadowful amounts for glasses that are the lightest possible.
One advantage of the OptiVisor is that each lens of my trifocals can utilize the magnification lenses. I can count count hairs on amoeba at one level ...
My problem is I don't have cataracts. They won't just yank and replace.
A project on my waiting list; I have all the bits (total cost less than 20 GB pounds plus scrapbox items), just no time to do it, I am too busy with intricate carving jobs using an optovisor clone. Priorities?
