China display cabinet
Norm Knoxville
Is there a standard depth and distance from the back of a cabinet for the groove that plates are positioned in to display vertically? Thanks.
Norm Knoxville
Re: China display cabinet
don stephan
Wonder if the question might be is there a standard angle for displaying plates, as this would cover plates and platters of different diameters?
Larry in nw ohio
Norm What I did with my china cabinet was to lay the plate on a flat surface and measure to the center of the rim and add a 1/16" or so, whatever looks good to you. No real science to it. Good Luck wirh your project and hope you post some pictures. Larry
Hal
Measured our china cabinet (made by Ethan Allen - about 40 yrs. old) One groove at 3/4"+ and one at 1-13/16" from back. This arrangement works OK for our assortment of plates. Hope this helps. Hal
Norm Knoxville
Thank you all! This info should do the trick. Norm
