Poly over watco
Poly over watco
Poly over watco
james jacomb
Running out of time on some gifts. Watco says wait 72 hours before applying poly over the oil. Any thoughts, experience, etc about pushing sooner. I'm thinking it's a matter of the distillants evaporating.
Re: Poly over watco
Re: Poly over watco
Dick Coers
I'd consider pushing it with lacquer, but definitely not poly. Actually, I wouldn't put poly over it anyway. Poly barely likes to stick to itself. Wait too long with poly, and you have to rough it up with sandpaper so it will stick. Good luck.
Re: Poly over watco
Re: Poly over watco
I'm thinking that, plus the time for the oil in the finish to complete its chemical cycle. I've had times, with Watco on porous woods, when I had to rub it down daily for three and even four days, as distillates popped out of the pores. I wouldn't push it, regardless of what film finish you're applying over it.
If you're not going to make it by Christmas, and the recipients are local, a photo of the piece in almost-finished condition, carefully wrapped, and a promise of delivery as soon as it's ready would be better than a piece on which the finish peels on December 26th.
Re: Poly over watco
Re: Poly over watco
james jacomb
Yea, I think I'll just wax after watco. I had a nice piece of ambrosia that I wanted oil on to help the grain pop, the rest of the lot is catalpa or willow so I won't push it. Thanks for the help!:)
Re: Poly over watco
Re: Poly over watco
That combination makes a beautiful finish.
Re: Poly over watco
Re: Poly over watco
Bruce, a MN Galoot
If you're lazy, you can also wait another day or so to let the Watco harden a bit more and then rub the dickens out of it with a t-shirt. It gets a really nice low, even sheen.
Re: Poly over watco
water or oil poly?
Robin Corell in Atascadero CA
I apply General's HP poly which is a water based poly acrrylic blend over the top of wet jasco brand tung oil with excelent results. If I let it dry I have to wait until it compleatly cures and then scuff it up, but if I do it while tthe oil is still wet I get 100% adhesion. It is something you have to try with the individual products you have and I would only try it with a water based poly.
Robin
