Raised Panel Problem
Tom Rex in TX
I'm making raised panel doors out of ash, trying to match doors in another cabinet in the room.
The top of the panel has an arch. When I try to cut the panel with my raised panel bit at 12000 rpm it is blowing the last part of the cut out. I'm taking very small cuts but the bit grabs the panel and pulls it into the bit.
How can I prevent this from happening?
T Rex=
Re: Raised Panel Problem
Kneale Brownson
Kneale Brownson
Are you using the router free-hand or in a table?
Finish the last part of the panel with...
roger lance
hand tools.
Keith Newton
Clamp a caul on the back edge where it will be supported when you do that part. Start out doing that part first, so you have a full thickness for the clamps. You might even have some extra length on the bottom, until you get that part worked out, then cut to length down there last, to keep from trashing parts.
Dick Coers
How many passes are you making? I run my panels by first cutting one end grain end, rotate the stock counter clockwise, run long grain, turn ccw, run other end grain, rotate ccw, then run the last long grain. This leaves material to clean up with the long grain pass. If the stock is really brittle, I have a large piece of scrap that I use as a push panel, and actually back up the panel as it cuts the end grain. The pusher should be big enough that you can actually feed it into the cutter as the good panel clears the cutter. A nice handle fastened to the push board makes it safer, and you can pull it back without running that entire side through the cutter. I use worn out jointer push blocks screwed to the face of the panel as the handle.
Tom Rex in TX
Table
Bob
Bob
Sometimes I glue a caul where I may get blow out.
Howard Acheson
The router bit is digging into the grain of the panel. The way to deal with this is to use a "back cut" technique. Instead of moving the piece into the bit, move the piece in the direction of the bit. Be sure you have a good grip on the piece and take very, very light (no depth) cuts.
del schisler
I belive this is mention do a back cut which mean's instead of feeding from the left to right , put the piece all the way to the right with out cut and move the piece back to make the cut but hold on to the piece real good because you are going with the direction of the bit and it will try and pull you back , so a good grig is in order just cut maybe a couple inches or 1 inch, i guess try and see which one work's best , just keep a good grip , this will stop the tare out
Bruce, a MN Galoot
What you describe is just what I do, too. Climb cutting in general produces a really nice cut, but is very hard to control. In this situation, only that last little bit needs to be fed backwards. I made a gripper thingie out of a mouse pad glued to a piece of wood, kinda looks like a small trowel. It works really well.
