chair leg repair.
chair leg repair.
chair leg repair.
In the next couple of weeks I've got to start on this chair leg repair. The actual repair is not problem. I'll dig out the crappy floating tenon that was in there and use a stronger wood. You an see where it was repaired once before by the paint on the veneer. That's where this question is headed. I've done a lot of Photo retouching over the years and done a little retouching on wood patches but this is going to take more work.
I've always used the water based artist paint that I have plenty of. However it can be tough to color match because the finish changes the color so it's pretty trial and error. What would you all use to paint the patched area to match the veneer?
Re: chair leg repair.
For me it's trial and mostly error
Henry (Raleigh, NC)
John:
Sorry I could not be more helpful, but for me it's trial and mostly error. I'll watch for better answers though.
Finish firewood first - wasn't that Michael's Dresner's (sp?) answer?
Henry
Tony-Memphis
I'm no pro, but i have used artist oil paints mixed with finish. Pigments mixed with finish work well too. I've even used ground up pastels with finish. Long ago, there was a refinishing show on PBS that I can't recall the name of. I wish like heck I could get the videos. He had lots of great tricks. I have a book I got at B&N on refinishing that has some good tricks too. Might be worth a visit to B&N for a cup of Starbucks while perusing their selections.
Tony
Jerry Gibbs
Not sure what mean by "patched area". If the patch is wood, I would use a toner approach, meaning colored film finish, starting light and getting darker. If the patch is solid, like Bondo, I would paint wood grain to match. The good thing about painting wood grain is that you can practice elsewhere.
I should have been more clear
There isn't any way to glue this back together and not have a gap filled with some kind of filler. So I will be coloring the filler. I was thinking about mixing paint with shellac so if I really don't like the look I get I can easily remove it. I've never tried this before.
Of course I will try it on scrap first and will have to use opaque colors to cover up the patch. Of course if the patched area blends in but the overall color is off then that is where the toner will come in.
Re: I should have been more clear
Keith Newton
Man John, it looks like they cut that leg out with a knot right in it. Before you get to figuring out how to finish it, you need to find a good way to repair it, where it will have some strength.
The former spline was not a bad idea, but it needed to be almost full width.
I always hate to get these things where someone has already done a poor job of fixing it, so there is thick glue in the break keeping any cell to cell contact across the joint. I usually go at it with a small grinder to get lots of the crap out of the way, so l can get the parts closer together, then use thickened epoxy to fill and bridge.
I would also try to get a router jigged up with an edge guide and long straight bit, which would allow me to cut a deep mortise most of the way across the front to back width of that leg, and about 3" each way.
Keith I think the knot was painted on. Possibly to help cover the earlier repair. When I have to repair something like this I use All-thread rod for my floating tenon. I know, it's probably not the official way to do it, but if you use 3 or 4 rods and thickened epoxy it is really strong because the threads help hold it to the glue.
I wax the wood up to the joint so it's really easy to wipe off the excess epoxy with alcohol.
Bob
Bob
I have used epoxy and a steel rod which has worked well.
don stephan
I've used fresco powders and shellac. Dip a fine tipped brush in the shellac, pick up a bit of fresco and smear around to get a uniform color, then begin touching up. Takes a while, but if it turns out too bad a wipe with denatured alcohol removes all for another try.
Thanks Don. I just wanted to find out if I was headed in the right direction.
Robin Corell in Atascadero CA
If it was me I would send it to Keith Newton and pay him to fix it :b , but I hate repairing chairs more than just about anything else.
As for the finish it depends a bit on what the original finish is but the approach is still the same. Don't aim for a perfect match the first time shoot for something lighter and do it in several coats. Seal it first and then use tinted shelac, varnish, or lacquer. Then adjust the next coat for tone (redness) and slowley sneak up on where you need to be. I find it easier to adjust for either tone or darknes but not for both in the same layer.
Robin
Thanks Robin, but,,,,,
Keith Newton
I would throw a chair out, if it broke like that.
Like you, I usually turn away repair work,,,,,, except for family and a few friends, or is a really fine piece worthy of my effort. Usually those find their way to me after someone else has demonstrated their high level of ineptitude at repair.
William Duffield
That would have been Joe L'Erario and Ed Feldman, the Furniture Guys. They had three shows, Furniture on the Mend, Furniture to Go, and Men in Tool Belts. I think they coined the term "curb furniture."
www.furnitureguys.com
Re: Thanks Robin, but,,,,,
Bruce, a MN Galoot
I used to repair chairs like that for a guy here at work. They were antiques to him, but were just old and not very good to begin with. I'm glad he retired because he's not around to pester me anymore.
You were there...
... when we had Joe and Ed as special guests at one of the American Woodworker Shows, weren't you? Or was that one of the Woodworks shows? Anyhow, I got to take them to lunch, and they're just as funny off the set as on. Lotsa good tricks, too.
E
Re: You were there...
William Duffield
Nope, I wasn't at that one, or at least I don't remember. :( I've never met them in person. Too bad. :(
Their shows have left a lasting impression, however, especially "Full Metal Tack Strip."
Hiding repair work *LINK*
Hi John,
When I was a product manager in the contract furniture industry, there was only one way our repair guys worked, and that was to use powdered pigments (I have not tried fresco powders, as Don mentioned) with lacquer or shellac. You use a tiny red sable artist's brush and paint in the missing detail to match the surroundings. Usually, you begin with the darkest colors, or the background color, and paint in the details such as grain, pore structure, etc., depending on how accurately you need to match the surrounding areas. Many years ago, Michael Dresdner wrote an excellent column for American Woodworker magazine about the technique.
Michael Dresdner's "Just Finishing" column
