Bookshelves nearly all done
Stephen Kirk
After what seems like a very long time (actually, since about March), a project to make 3 bookshelves is finally drawing to a close. 2 of the 3 are completed and have books on them, while the 3rd just needs it's shelves built.
The frame pieces and the front molding of the shelves is red oak, with the panels made from birch ply. The sides have 1/2" ply while the back has 1/4". Construction is mortise & tenon and grooves for the panels.
Finish is a several step process, starting with a dye coat of lemon yellow (I used water based), a seal coat of shellac, glaze with Antique Walnut stain (General) and finally 3 sprayed on coats of General's Water Based Enduro Var.
If you haven't dyed before, I suggest making a lot of samples and knowing it will look better. That is some really bright, flat yellow!
The shelves are torsion boxes to give a lot of strength as they are 38" long. It's more work to make, but they are very strong and light and easily carry the weight of a full load of books. Skins are 1/8" ply with 3/4" MDF on about 2" squares. I was going to make cove molding to match the top for the fronts of the shelves, but time was wearing on and I needed to get done, so I opted for a simple bullnose. They still look good.
I learned a lot on this project, especially about spraying. I was getting some moderate orange peel. After reading, getting a finer tip and experimenting, I found my problem was a combination of spraying too heavy and too far away. I have the Earlex 5500, with the smallest tip, little flow and staying about 6" away I started getting surfaces much more smooth and glass-like. Once getting good results I really started to like spraying.
These will replace our old pressboard bookshelves (which may still stay in the house for some other duty). Good bookshelves can really change the look of a room.
Re: Bookshelves nearly all done
looks good, like the shelves
Larry in nw ohio
Stephen Looks good and as you say you learned a lot from this project, so it was a very good use of the time you put in on it. You did a great job. Larry
