I have a couple of 18 volt DeWalt batteries that went bad but instead of having them rebuilt would the Li-Ion battery work in them. Has anyone tried them and if they work is there any kind of drawback? Thank You Larry
The Lithium Ion batteries WILL work in your cordless drill, but you'll need a new charger specifically for Lithium Ion batteries. The BIG difference is that Lithium Ion battery CELLs MUST BE BALANCED while charging, therefore taking a special charger. You could NOT charge the Lithium Ion batteries with your current Dewalt charger. You REALLY risk destroying your batteries and causing a fire. The same goes for Lithium Polymer battery packs.
Therefore, I'm assuming that Dewalt, like Ryobi has made it so you can purchase a Lithium Ion batteries and a Lithium Ion battery charger to sort of retro-fit or upgrade your Dewalt. If NOT, you're stick with the NiCad or NiMih battery packs you're currently using.
David and Don, I did a little more digging after I posted, and I came up with is if it fits the drill or whatever you have, except a circular saw, it will work. I read nothing against it. But as David said you must use a lithium charger and not the older chargers. Thanks guys. Larry
You might want to consider the feasibility of upgrading the batteries versus replacing the tool. Rechargeable batteries are not cheap. When you buy two batteries and a new charger, you are probably approaching the cost of an entirely new tool.........which would include two new batteries, a new charger and a NEW tool. Make sure this makes economic sense before going any further.
No Problem, as soon as I get some time on them. But everyone that answered my question on that didn`thave anything negative to say about the. Also they yell me that batteries are purposely made for a drill that if it is not made to run such and such a drill, it will not fit. So they should be OK. Larry
That probably is a good price. I know, I priced a battery for an older Panasonic cordless drill once. The batteries were $59.95 each. I didn't have to have a new charger, but I only paid $159.95 for the drill, two batteries, a charger and case. I had the batteries rebuilt at Batteries Plus for $30 each, but finally replaced the entire drill with a Dewalt, 12 volt lithium-ion driver-drill combo. I got a drill, an impact driver, two batteries, a charger, a tool bag and a bonus battery.
