OT Car battery's
Dustmaker Mike
Did I miss something in the last few years? My wife's Explorer needs a battery I just went checking around and well let's just say a few years ago I could buy two for the price of a new ones today. Wow
OT Car battery's
Dustmaker Mike
Re: OT Car battery's
Richard McComas
The US dollar ain't what it use to be.
Bruce, a MN Galoot
Neither is the price of lead.
Yup ! AND . . .
steve mackay
. . . that is WITH the old one. Dude told me that and I drove home to get tools so I could change it in the parking lot.
RobCarr
Just last week bought one for my Expedition - $160 bucks from Autozone... before that I think I spent about $110 6 years ago.
John Veerkamp
Recently spent $153 for a battery for my Buick Lucerne.
Brian from Monument
If the prices for car batteries scare the heck out of you then don't get into motor homes. The house batteries, which are deep cycle, are like 4 times what the car batteries are a piece. My RV started with 4 6 volt batteries I have replaced them already as they froze last winter. Now I have 6 batteries shouldn't freeze again.
why they froze
Bill Tindall
Fully charged the battery liquid is sulfuric acid which has a very low freezing point. Fully discharged the battery contains water (more or less) whch freezes when it gets cold.
Lead batteries self discharge. If you store a lead battery in a freezing environment it will eventually self discharge and freeze. Must store warm or better, keep connected to trickle charger.
Wandering O-OT, charging problem...
John in NM
This one has me a bit stumped, and parts are a bit expensive to play parts bingo these days.
Antique (1987) Toyota, charge light comes on when you start it up. I've driven it a bit that way, down to the Post Office, etc. Shut it off and the battery is basically flat, even if the trip was short, like 100 yards. Wait a while and it will crank and start again.
All I can figure is there must be a shorted diode in the alternator, basically pulling a lot of juice out of the battery as it attempts to charge. Let the battery recover a bit - like a day - and it has enough oomph to crank again.
But that may be wishful thinking -- I'd be wishing that because batteries now cost 3x a rebuilt alternator
I also thought it could be a shorted cell in the battery, but I can't figure how it would work at all if it were that.
Re: Wandering O-OT, charging problem...
John McGaw (Bodger)
Easiest thing in the world to test it and know for sure rather than theorizing. Many auto parts emporiums have the equipment to check for battery/charging/starting system problems and they do it for free in hopes that you'll buy parts from them in the end. The closest one to me that does this is Advance Auto Parts but others offer the same service.
Bill Howatt
I've had batteries with a bad cell and I never had the charge light come on once I boosted it to get it going (and it wouldn't restart the car after I shut it off). My guess is the alternator/regulator which I think are all-in-one these days. You could put in another battery for a test.
Bill
Bought tires lately?
Mike Farinella
You're in for another sticker shock. Just bought 4 for ~ $1000. Gulp!
Yes.
Joe in a Cleveland suburb
My car requires two different size tires front/rear (factory spec size).
A good set is over $1000...
Yup second set
Dustmaker Mike
I had to buy. First set was for my truck a little $1100 the second set was for the wifes Explorer $1000 some times I think it would be cheaper to replace the car or truck instead of repairing it. Then I look at car payments and think again
Pete in Holland, MI
Batteries age quicker when half dead and especially near or fully dead, where they will freeze. Lots of articles on-line show this.
If you don't run a vehicle and it sits for long periods (like motor homes, equipment at cottages, summer vehicles like motor cycles, cars & lawn tractors in storage for winter, etc), "battery minders" are the thing.
Those of us in the antique tractor have found the value of these little $20-30 gizzies in keeping our batteries going for many years. Keeps the battery topped up, where it will live the longest.
Placing a standard charger on a battery is not the way to go. Battery minders have the ability to monitor the charge and trickle in more when needed, without the concern of over charging a battery.
Pete
Re: Bought tires lately?
Our new to us car has those fashionable large-diameter wheels, which means very short sidewalls on the tires. We've had to replace two due to road damage*, and we haven't had the car for a year yet.
I will never again buy a car with great big wheels, unless it's a 1930s Lincoln or similar car.
*The short sidewall means they don't flex much, which also means that, if they hit a pothole, they get damaged more easily. Since potholes are one of the major crops in our county - the roads department has, quite seriously, proposed to stop maintaining 90% of the roads in the county - this is a significant problem.
RobCarr
Do you have a voltage meter?
With the vehicle off the battery should read about 12.5 volts (fully charged). If its under 12 volts replace the battery.
Then start the vehicle and measure it again, it should be over 13 volts with the engine running. If not the regulator had probably gone bad which means replacing the alternator.
RobCarr
Are there any particular brands in battery minders to look for? I used to use an old 2-amp charger to keep batteries charged over the winter months, but I don't think it used any kind of regulator and I think it ultimately cooked the batteries.
Pete in Holland, MI
Walmart, Tractor Supply, Farm & Home all handle them. Some automatically detect between 6 & 12 volt (critical for us old tractor guys).
Battery minders and trickle chargers are two different things built for two different purposes.
Pete
What am I missing here?
Henry Higginbotham
I've heard several discussions lately about tire prices being way up, and most seemed to be claiming that the increase has been dramatic in the last year or two.
I last put tires on my car in March, 2009. A set of four Bridgestone G019s, 225-55/16, was $436 back then. Today, they're $452. Up $4 a tire after almost four years. Maybe they're being made in Asia now?
I'm not disputing that others are seeing big price jumps, just asking what I'm missing. Something, surely.
Well for me I am
Dustmaker Mike
buying Goodyear Silent Armour 245/75/17 for the wifes and Yokohama ATS E load rating for my truck 275/75/17
I have not had to buy a set of tires in almost 10 years before these two sets.
At a guess...
John in NM
A lot of newer vehicles take strangely huge tires, I think that accounts for a lot of it, but without knowing the specifics of each case I could well be wrong.
I tend to run the same car for years, and my current one takes the same tires as the last one. Prices are up maybe $100 on a set for me, 2008 vs. 2012, but even so they're only $400 for a set. Little tires of un-fashionable profile
My work truck is one of the modern huge-mobile things that has 17" rims where 15" used to suffice. No rhyme or reason to it, just fashion and added cost.
Re: why they froze
Brian from Monument
They froze because the charger was not on long enough to keep them fully charged,
Since I have had the batteries replaced enmasse and put a bank of solar panels in place to charge the batteries.
This will keep the acids fizzling and the batteries warm.
This happeneed because the RV was in a storage area not my garage.
If it had been near my house I could have kept a charger on it.
But then i had only my occasional visit to run the engine for 30 minutes.
Solar panels should keep it working.
Dick Stariha
Brian,
I hope you don't mind a " mine is bigger than yours story" LOL
My battery bank for my home solar system requires 12 large batteries @ over $400- each
DS
Could be "starter drag".
basil
Could be starter drag. Cold start works just fine but when starter gets warm it'll act like a dead or weak battery. When the starter has cooled enough, it spins it over just fine.
I've had this problem many times over the years.
