OT Storm shelter eiit problem
Dick Stariha
Not exactly a wood working question but I may have to form up some concrete forms for it.
I think this is the best place to look for how to engineer my problem.Bear with me . A little back ground:
I already have a storm shelter ,below grade ,attached to residence, with a 10" reinforced concrete ceiling(roof) ,setting on concrete block walls.
The room is 24'x30'. A chimney opening in the NE corner and a fresh air vent in the NW corner. With a little advanced warning a 2' of layer of soil could be dumped on the "roof" and the room could double as a NBC shelter.
My need is a second exit. If the primary entrance(exit) is blocked, the occupants would be trapped(SOL).
My plan is to buy a 42" culvert( corrugated steel), trench down on the outside of the "room" and have an exit to daylight thru the culvert. ( and obviously thru a previously constructed hole in the c block wall).
OK . How does one attach the culvert to the wall and make it secure and water proof?
Thanks in advance,
DS
Re: OT Storm shelter eiit problem
just an idea on an exit......
roger lance
if you were to place your culvert on the outside so that you could get out....why not simply mark out on the inside where the doorway should be without actually putting it in......but have a nice sludge hammer handy in the shelter.....doesn't take much to bust a hole in a block wall.....you could have a number of such potential exits established just in case one or more got blocked.
You could insert the culvert into the hole in the block wall and then grout it with a non shrinking grout. Find a commercial/industrial or sewer contractor that build the drainage systems for highways. They commonly install culverts into manholes and drop inlets. Many of those are precast now and include a rubber/neoprene gasket. It may be possible to incorporate one into your situation.
John McGaw (Bodger)
This is just winging it but, if you have that massive underground room you must be comfortable with excavation. How about just excavating a square opening where you want the exit, pouring a footing in the bottom and building the exit well with blocks, same as the room itself? It would seem that the emergency exit might not even need to be as deep as the regular entrance/exit since it won't be used normally; a short ladder on the inside wall extending up to a hatch in the wall at waist height or even higher should do the trick for an emergency bailout (barring handicap access needs). Since you would be dealing with concrete block for old and new, sealing the new structure to the existing structure could follow industry standards (I'm not even sure what those are right now but I'm certain that they exist).
